Changing from axle joints? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2009, 08:06 PM   #1
Offroadexpy
Rockin' the Stocker'
Offroadexpy's Avatar
Default Changing from axle joints?
Couple questions...
Vehicle 79 F150 4x4
1- How hard is it to get the hub apart? It does not have lockouts...so im assuming its some sort of spline with a nut and lock washer?
2- once apart...how does the axle shaft come out? Does it got a C clip inside the diff cover, or do they just slide out? or what...ive never changed one before.
Thanks guys.
Offroadexpy is offline   Reply With Quote
Old October 12th, 2009, 08:09 PM   #2
boggin-machine
boggin-machine's Avatar
they just pull out once you have the hub and everything off of the spindle. the spindle must come off as well. most will need a spindle socket with the slide hammer to remove unless it was off lately.
Page generated in 0.15552 seconds with 29 queries
