Whats the best route for more load capacity in the rear - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2009, 03:45 PM   #1
Gunsworth
Gunsworth's Avatar
Default Whats the best route for more load capacity in the rear
I have an 01 2500HD and load it to the max quite a bit, I dont want to go crazy, just dont want to worry as much. Would some 3500 springs work, or should Ijust do an add-a-leaf (never been a fan of aal)
Old October 12th, 2009, 04:04 PM   #2
Bow_Extreme
Bow_Extreme's Avatar
Air Bags.
Bow_Extreme is offline   Reply With Quote
Old October 12th, 2009, 05:03 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
this goes back a few years, but we had a dumb body shop manager back at the dealer for a while. he managed to sell his inlaws the wrong truck for thier needs. it was a light 2500 extended cab long box with 8600 GVW. anyways the guy went and bought a 3400lb slide in camper. it squated that truck so bad it wasn't funny. the body shop manager said he'd take care of it. he had it taken to Arc Spring in Ypsi. it came back sitting level...and we laughed our asses off. it now had 16 spring on each side about 8" tall! that truck rode like shit from all that and then it started having axle issues...what a dumb ass.
so the moral of the story is how much do you need? vs. how much do you want?
Yetti
Old October 12th, 2009, 05:59 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
x2 for air bags
Old October 13th, 2009, 05:19 PM   #5
Gunsworth
Gunsworth's Avatar
ok, local spring shop can put in a an extra leaf for 270$ thats less than the air bags and installed. you guys have any reasoning for air bags other than even more capacity and adjustability.
And no I am not gonna do some ghetto shit with 16 springs, truck is already a 3/4 ton I am not looking to overload the hell out of it, but I come close quite often and just dont want to worry about blowing out my springs or getting rolled for looking like I am over. Being an HD it has the same rear axle as the 3500s only srw. I will also be using range E tires
Old October 13th, 2009, 08:19 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
A extra leaf will gain you a bit on height and a more rougher ride. And it will always be like that. With bags if you're going to haul a big load, pump the bags up and when you're done air then down some. They ride like stock. I've done many airbag kits on that truck and it's dead simple. No drilling and it all bolts on. I install Airlift stuff.
In my opinion, you would be money ahead with bags. But that's me.
Old October 13th, 2009, 08:23 PM   #7
SBC YJ
Heavy Chevy
SBC YJ's Avatar
air bags
SBC YJ is offline   Reply With Quote
Old October 13th, 2009, 09:13 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
air bags can be there when you need them and not noticeable when you don't. when you put extra leaves in the rear you can feel it all the time. when not loaded it rides like a tank typically. the only thing that is a good idea for extra leaf is a double wrapped spring. such as this
this prevents the main leaf from snapping which is a common problem when loading heavy and using too stiff of a leaf pack.
Old October 13th, 2009, 09:51 PM   #9
curt1656
Praise the lowered
curt1656's Avatar
Bagz, and done.
Old October 14th, 2009, 03:13 PM   #10
Gunsworth
Gunsworth's Avatar
Alright I will probably go with the bags then, I will probably just leave em aired up though since I am under load probably 90% of the time (which is why I wouldnt mind the rough ride 10% of the time with an aal) but since not a single person recommended anything other than the bags I guess its an easy choice. Does the brand really matter with these, Ill look into the air-lift as mentioned earlier
Old October 14th, 2009, 05:15 PM   #11
jbsjunk
Little Member
jbsjunk's Avatar
I have alot of experience with Air Lift, but other companies should be similar. The Air Lift is bolt on, you remove the bump stops as the kit uses that location for it's mounting. I've had customers put them in in our parking lot.
Bottom line is it's still up to you what you want to do.
Old October 14th, 2009, 05:40 PM   #12
I96safetyguy
I96safetyguy's Avatar
airbags are the only way to go.
I96safetyguy is offline   Reply With Quote
Old October 14th, 2009, 07:29 PM   #13
xjmichigan
xjmichigan's Avatar
These are good for an extra 1200lbs
http://www.monroe.com/products/maxair.asp
Old October 15th, 2009, 10:25 AM   #14
Gunsworth
Gunsworth's Avatar
used those in the past with my dads plow jeep, I feel that the airbags would hold up better, and I just got new shocks this summer
Page generated in 0.35668 seconds with 65 queries
