Eastwood HotCoat Powdercoating session today - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2009, 10:20 PM   #21
amundaza
Terminator 2
amundaza's Avatar
Tonight, I sprayed SILVER VEIN on the 3 good FSJ Wide Track center caps that I have. These will be going on the WT rims I did up in MIRROR BLACK and will end up on
my buddys Grand Wagoneer
heading for Guatemala soon.
Here's how they turned out.
Sincerely,
Greg Taylor
Rochester Hills, MI
1989 Grand Wagoneer "Terminator 2"
330" AMC stroker V8
amundaza is offline   Reply With Quote
Old January 5th, 2010, 09:21 PM   #22
amundaza
Terminator 2
amundaza's Avatar
Default Today's powdercoating fun ....
Hey guys,
Been a while since I posted on this threaad. I did some more powdercoating today. A longtime friend in our local AMC club asked me to powdercoat some Plymouth Duster, Cuda and a Javelin plasma cut designs. I bead-blasted them first. The Duster was done in Smoke Chrome and the Cuda in Mirror Chrome ... the Javelin still needs some clean-up work from the plasma cutter edges.
I blasted the early 70's Full Size Jeep "V8" badges and shot them in Mirror Chrome. I may go back and add in the RWB sections with testors enamel, as suggested previously by a member on the IFJSA.org forums. Here are some pics.
Old January 6th, 2010, 06:44 PM   #23
Sandals
Fucking Zen as Shit
Sandals's Avatar
Hand painting those V8 emblems would be awesome
Old January 6th, 2010, 07:30 PM   #24
amundaza
Terminator 2
amundaza's Avatar
Thanks ... I'm thinking about painting them in a deeper/brighter red and blue, than they were originally.
Old January 7th, 2010, 10:56 PM   #25
TBSdontstop
TBSdontstop's Avatar
Now I need to find an old oven and get a powder coating system the parts look great.
TBSdontstop is offline   Reply With Quote
Old January 7th, 2010, 11:11 PM   #26
amundaza
Terminator 2
amundaza's Avatar
Just check out the free section on Craigslist ... free ovens pop up there periodically. I got my Eastwood Hot Coat system on Ebay, used, for a good price. Thanks for the kudos. I'm currently working on powdercoating a HUGE bench vise for a buddy of mine. I'll post pics when it's done.
Old January 8th, 2010, 07:24 PM   #27
lgottler
lgottler's Avatar
FIgured I'd chime in here on the Eastwood Hot Coat setup. My only setup difference is we have a digital lab oven that can bracket a temp +/- 1 degree.
I bought the same thing for a starter kit for work. Tired of paying $100 for a same day emergency paint job on prototypes.
For general use, works great. However, I already want different diffuser patterns for the nozzle and doing 3/8" plate it would be nice to have more voltage for wraparound too.
As far as prep work goes, I cut 20 different test strips of metal and marked numbers on them. Then I prepped them all different ways.
The highlights for prepping metal:
What doesn't work:
Anti-Spatter
Water droplets
60 grit or coarser sandpaper
Felt tip marker
Paint marker
What didn't make a noticable difference in appearance:
Sandblasting first
Just wiping off parts with a rag
Scotchbrite
oil and wipe off
wd-40 and wipe off
degreaser
Pre-heat to about 350 makes for a really nice thick coat, sticks and builds up. I haven't had luck rehitting an already cooked part yet.
Lucas
lgottler is offline   Reply With Quote
Old January 10th, 2010, 10:26 PM   #28
amundaza
Terminator 2
amundaza's Avatar
Hey Lucas,
Thanks for the feedback and input on what you have tried.
On Saturday, I got my first chance at re-hitting a coated part. I was coating a 50-lb bench vise for a buddy and hit one part of it with the WRONG COLOR ... DOH! I sprayed most of it in Silver Vein and accidentally did the arm in Smoke Chome.
Luckily, I have been reading on the Eastwood powdercoating forum about rehitting coated parts. The trick is to do it while they are still HOT. Spraying powder on the hot parts, causes it to flash melt. Then you just put it in the oven and back away.
I did this with the bench vise arm and it turned out great. I also did it with the handle (in Smoke Chrome for an accent), since the handle can not be removed out of the screw mechanism.
I'll post up more pics later.
Old January 13th, 2010, 08:58 PM   #29
amundaza
Terminator 2
amundaza's Avatar
Default BIG oven from a Fridge
Here are the beginning pics of and old fridge being converted into an oven. I am currently stripping the fridge down. Nice thing is that the OLDER refridgerators have fiberglass insulation instead of FOAM insulation, which comes out A LOT easier. Guys on the powdercoat forums were having to air chisel the foam out of the newer fridges they converted over.
This one will have TWO oven burners in it, and a fan most likely, to circulate the air for even heating.
Old January 13th, 2010, 08:59 PM   #30
amundaza
Terminator 2
amundaza's Avatar
Default Bench vise
Here are before and after pics of the BIG bench vise I did for a buddy.
Old January 16th, 2010, 11:13 PM   #31
amundaza
Terminator 2
amundaza's Avatar
Default AMC I6 4-bbl intake
Hey guys,
I picked up a super sweet Offy dual-port intake for the AMC inline sixes, today. It was supposedly new and very well could have been. Either way, I got it bead-blasted tonight and powdercoated in Mirror Chrome.
I also sprayed the powdercoat differently tonight. I pre-heated the parts first for about 18 minutes, then sprayed them with powder, which flash melts on the hot surface. Then baked them to cure the powder. I like how the finish turned out better on this, than on the last intake I did.
Here are the pics. I also included a pic showing part of the intake with a bead-blasted area, so you can see the before/after difference on the same part.
Old January 16th, 2010, 11:51 PM   #32
amundaza
Terminator 2
amundaza's Avatar
Hey guys,
Just want to share this tidbit of information on converting a fridge/freezer into an powdercoating oven. I saw on some of the conversion threads that guys were using newer fridges/freezers with a styrofoam liner. The liner needed to be chiselled out ... which is very time consuming.
What I have discovered is that the OLDER ice boxes have the yellow fiberglass insulation in them, which is not adherred to the outer shell. They come apart rather quickly.
Here are pics of me gutting the freezer I picked up, while my intake manifold was pre-heating, then baking in the oven. I got this one gutted in about 35 minutes.
BTW, I now have 3 fridges & 1 freezer, which I'll be using to make ONE oven and ONE spray booth from.
Old January 17th, 2010, 09:25 AM   #33
bigden
94 YJ
bigden's Avatar
This is a great idea. I have started an oven out of a old liquid propane tank. I think my plans may chanege. Keep us posted.
bigden is offline   Reply With Quote
Old January 19th, 2010, 03:22 PM   #34
amundaza
Terminator 2
amundaza's Avatar
Default More progress on the fridge conversion
Hey guys,
Got a little more done on the fridge conversion today. The magical Craigslist fairy decided to help out ... and with wave of his wand ... POOF! Here's where I'm at now ...
Old January 23rd, 2010, 06:52 PM   #35
amundaza
Terminator 2
amundaza's Avatar
Default Roxul & exterior sheeting
Yesterday I picked up 3 bags of 3" Roxul mineral wool. This is the high-temp insulation that will line the walls of the oven.
Today, I was going to go pick up some steel sheeting for the outside, but the sheet metal company only had 20 gauge cold-rolled ... no thinner gauge galvanized. So, I called a couple of heating & cooling places this AM. One that's about 2 miles from my house had 3x8 sheets of 26 gauge galvanized in stock.
So I pay for 5 sheets of it and while we're loading it, I mention to the guy that I'll be cutting and bending it at home (by hand) ... he offers to do it all for me there. In about 20 minutes, we had the sheets cut and pre-bent and loaded in the van, since I had the oven dimensions with me. That saved me probably 10 hours of work at home!
Old January 25th, 2010, 10:23 PM   #36
amundaza
Terminator 2
amundaza's Avatar
Default Progress ...
Tonight, I went around with the MIG welder and welded all the drywall studs together, to make the framework more rigid (than just being pop-riveted together). I still want to add more supports to the floor framework, than the original oven builder did. The floor is still just too flimsy to handle any real weight (like an engine block or differential).
I also picked up some high-temp appliance 12-gauge wire from a local supplier.
Old January 25th, 2010, 10:25 PM   #37
xj97sport
atv rider
xj97sport's Avatar
Wow, those turned out great. Did you try testing the durability of the coating where the tire goes on the rim?
Scratching it or anything?
Maybe throw a rock at it
Old January 26th, 2010, 08:13 AM   #38
bigden
94 YJ
bigden's Avatar
This is very cool. Keep us posted.
Old January 26th, 2010, 09:01 AM   #39
amundaza
Terminator 2
amundaza's Avatar
Thanks ... will do. I'll post up more pics as I make progress on it.
Old February 9th, 2010, 03:53 PM   #40
amundaza
Terminator 2
amundaza's Avatar
Default Today's progress on the oven build
I got more of the bottom of the oven reinforced today. Triangulated the corners where the casters will be, as well as reinforced 90-degrees across the center, for handling weight in the bottom of oven. Last two pics are of the convection oven fan from the Double Whirlpool wall oven I'm scavenging for misc. parts (lights, fans, etc).
Page generated in 0.51395 seconds with 84 queries
