Ford Explorer Slave cylinder Failing Constantly!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2009, 09:49 AM   #1
fsumotorhead
N8KVB
fsumotorhead's Avatar
Default Ford Explorer Slave cylinder Failing Constantly!!!
Well my slave cylinder went out on my explorer yesterday for the third time in two years. Funny story actually, I ended up running my own mailbox over when the clutch failed to disengage
The first was the original slave from Ford, the second was a motorcraft part that only lasted 8 months, and the now third was an Autozone special and lasted about 15 months. Every one failed in the same fashion with them springing a leak internally.
Why canít I seem to get one to last? It is a major pain in the ass to change these on the garage floor, though I can do it in about 4 or 5 hours now.
Is it possible dirt/mud could destroy these?
any insight is appreciated
Old October 12th, 2009, 07:31 PM   #2
Never_Evil
You might want to use your clutch less, use it only to start your vehicle from a stop or when decelerating. The rest of the time you can get up to speed and shift it without pressing in the clutch. It gets wore out where the throwout bearing rides on the slave cylinder and rubs a hole in the slave.
Old October 12th, 2009, 08:30 PM   #3
fsumotorhead
N8KVB
Since Feb i hardly drive it, i don't DD it anymore
maybe once or twice a month, maybe 20000mi since the last slave
Old October 16th, 2009, 02:55 PM   #4
fsumotorhead
N8KVB
apparently it was a year and 5 months since the last one, so probably like 40K since being changed
any other insight into the failure?
Old October 16th, 2009, 03:01 PM   #5
I was having alot of failures with slave in my m5ord. The seal gets eaten up from all the mud/dirt etc..
I took mine out and got some screen mesh ( like from Lowe's for house windows). I made a few plates, drilled a few holes in bell housing and covered the openings with the mesh to keep the larger nasty's out. I was replacing a slave a year, now they are easily lasting twice as long since doing this.
Also make sure the fluid itself is good and clean.
Old October 16th, 2009, 07:41 PM   #6
Never_Evil
Its 10 gallons of s#!t fit into a 5 gallon bucket, any other questions?
Page generated in 0.15474 seconds with 41 queries
