02 f150 rear end vibration - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 11th, 2009, 07:15 PM   #1
warriorwynn
warriorwynn's Avatar
Default 02 f150 rear end vibration
have an 02 f150 5.4 and when i am stoped and turn the rear end vibrates. Only does it when i turn. replaced the rotors and didnt help wondering if the clutch packs are going bad but had them replaced around 25000 miles ago. Well take some help if any one has had the same problem
warriorwynn is offline   Reply With Quote
Old October 12th, 2009, 08:35 AM   #2
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
did you put friction modifier in it ?
Old October 13th, 2009, 06:20 AM   #3
warriorwynn
yep ford did it under warranty
Old October 15th, 2009, 04:27 PM   #4
warriorwynn
any other ideas
Old October 15th, 2009, 04:50 PM   #5
7.3X
Fullsize support vehicle
7.3X's Avatar
Fords shitty limited slip. I had one rebuilt and it lasted less than 10,000 miles.
7.3X is offline   Reply With Quote
Old October 20th, 2009, 04:20 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
mine did that too. i thought i blew the limited slip. as a last ditch effort i changed the fluid and added 2 bottles of friction modifier. 2 days later it was all better.
you might even just add some extra friction modifier if you dont wanna change the fluid.
good luck
Old October 20th, 2009, 07:08 PM   #7
warriorwynn
thanks that is what i was going to try next
Page generated in 0.22320 seconds with 44 queries
