4.10 gears? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2005, 10:46 PM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default 4.10 gears?
Seems like 4th gear is too low and 5th too high when towing. 4.10's would add about 250 RPM's...
Does anybody have a 5.9 with 4.10's? I'm running 265 tires currently. Trying to see if it kills or helps gas mileage also
JcrOffroad
Zoom Zoom!
Old November 6th, 2005, 12:25 AM   #2
Grandman
do i look old !
Grandman's Avatar
Im running a 5.2 with 4:10 s and 34 " tires which put me back at stock gearing for the tire change . Orginally was on 235 - 15
Old November 6th, 2005, 12:39 AM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Kind of off-topic, but I'm still trying to figure out what the ratio in my truck is. Someone said with the off-road package and towing package you got the 3.92, but I'm not too sure.
2400 RPM @ 80 mph on 275/70R17's 5.9L V8
Hope that helps....the axle ratio also isn't listed on the window sticker.
Old November 6th, 2005, 12:43 AM   #4
Chop
Mischievous Badger
Chop's Avatar
haha take the diff cover off and count
Old November 6th, 2005, 12:46 AM   #5
GreaseMonkey
Pew pew!
You buying the new diff. fluid for me?
Old November 6th, 2005, 12:51 AM   #6
PavementPounder
PavementPounder's Avatar
Go to Dodgeram.org and look it up.
BTW, I have a set of D60 4.56's that I would like to sell. They were installed and driven for about 1/4 mile and then yanked for 4.88's.
Old November 6th, 2005, 12:51 AM   #7
Chop
Mischievous Badger
Chop's Avatar
no your right you would have to change your fluid now wouldent you. :tonka:
Old November 6th, 2005, 01:54 AM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Just look at the dang tag :smack:
I currently have 3.55's...
JcrOffroad
Zoom Zoom!
Old November 6th, 2005, 01:55 AM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Hrmmm... tempting... but i'm not going up in tire size so that may be too much...
JcrOffroad
Zoom Zoom!
Old November 6th, 2005, 04:20 AM   #10
GreaseMonkey
Pew pew!
Woohoo...I've got the 3.92...
ok that was kind of
Old November 10th, 2005, 02:25 AM   #11
noodles
give 'er sh*t ay?
noodles's Avatar
im runing the 3.55, and i go between 31's and 35's and i only have the 5.2l
Old November 10th, 2005, 03:09 AM   #12
Mclovin
"The Situation"
Mclovin's Avatar
i know with older chevy's they have a code in the bottom of the glove box that tells you.. i duno about dodge but jeff figured it out so..
Old November 10th, 2005, 10:47 AM   #13
GreaseMonkey
Pew pew!
Yep, just a little math that's all.
Old November 10th, 2005, 11:55 AM   #14
Fronts a Dana 44, isn't it just stamped on the cover tags, Greasemonkey?
MonkeyEvil(whats with all the damn monkeys around here?) I had a 2000 Dodge ram, 2500HD 4x4 ext cab, long bed, camper special package.
5.9 liter with 4.10 gears. It got terrible mileage. The truck is just too big for that 5.9. 9-10 city, 12 hwy-13, 8 towing.
Funny, with 4.10 gears, I always felt that it was in between. In 3rd gear, 65 mph was running the engine too fast, and 4th gear was not enough power. I always thought that with the 3.54s, it'd have been OK to run the OD off and cruise in 3rd gear at 65 mpg.
I used to tow at 80mph, so that I had the engine in a good range. Towed better at 80 than a 65 in fourth gear.
I'd never waste my time with a 5.9 truck again.
Old November 10th, 2005, 01:27 PM   #15
GreaseMonkey
Pew pew!
'01 half ton reg. cab 4x4 short bed 5.9L 3.92 gears and doing 80 on the freeway I get about 15-16. Drop it down to 70 and I get almost 18.
Old November 18th, 2005, 06:43 PM   #16
sonic
sonic's Avatar
I have a 2001 ram 1500 with the off road package that came with a 5.9L and 4:10 gears and with the 39 inch tires i can still cruise down the freeway at 75 miles an hour with no problem. I really like the set up I have as far as that goes. Sometimes I wish I had a lower gear for wheelen but since I drive it on road quite a bit it works out well. There may be a sticker inside your glove box that tells you what gears you have. You could also try asking the dealer if they can find out for you using your vin if all else fails.
sonic is offline   Reply With Quote
Old November 18th, 2005, 07:38 PM   #17
PavementPounder
It should be on the tag on the underside of your hood.
39" tires with only 4.10's?
Old November 19th, 2005, 05:36 PM   #18
sonic
sonic's Avatar
yeah why?
Could put 4:56's in there if I really wanted to but this seems to be a very good all around set up. I also like that I can still go over 70mph if I want with out too much effort. I suprise a lot of people with what this truck can do for as little as I have done to it.
Old November 28th, 2005, 01:27 PM   #19
noodles
give 'er sh*t ay?
noodles's Avatar
do you have any pictures of your truck sonic?? Does anyone know where to get cheep gears?? I was wanting to drop mine down to a 3.90 or a 4.10 for the 35s I only have the 5.2 though.. so it already sucks.
Old November 29th, 2005, 08:29 PM   #20
sonic
sonic's Avatar
Here ya go...
http://i6.photobucket.com/albums/y246/sonic1gk/th_moundswT004.jpg[/IMG][/URL]
Page generated in 0.41221 seconds with 83 queries
