Front Leveler Kit ? Anyone install one ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2009, 08:39 PM   #1
getsome
Lookin 4 Accessories
getsome's Avatar
Default Front Leveler Kit ? Anyone install one ?
2009 GMC Sierra 1500 4WD --- anyone install or know anyone with a kit ?
Thinking about 2.5" billet spacer on top of coil.
I see now they have a kit including the 1" rear block also.
Is this really necessary ? what are the results ? I measure 3" difference from front to rear above the tires. Any opinions or help appreciated. I hate the front dive down look I have stock. thanks JIM
getsome is offline   Reply With Quote
Old October 7th, 2009, 10:42 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
I've done many of these. Pretty easy. If you put a 2 1/2 spacer over the coil, you're going to most likely gain 4"+ actual because of the geometry. Most spacer lifts are 3/4-1" that will gain approx 2".
Here is what I normally put on with great results.
http://www.readylift.com/c-122-new-k...6-lug-225.aspx
Old October 8th, 2009, 12:48 PM   #3
getsome
getsome's Avatar
Thanks for the input, very informative. I am just looking to level and install air bags in rear only for slide in camper. I have seen two other trucks w/ 1" bottom shims only and looks like what I want. Would you happen to have access to these and get me a rough print dimension to make some, (top ring or bottoms) Hole space, U shape size, etc... that would be most appreciated. thanks again.
Old October 8th, 2009, 01:07 PM   #4
CreativeFab
used to be Ironman
CreativeFab's Avatar
If you decide to buy give me a shout for some pricing!
Pat
989 832 7538
Page generated in 0.23192 seconds with 35 queries
