Machining polyethylene... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2009, 01:05 PM   #1
Dirt_Devil
Dirt_Devil's Avatar
Default Machining polyethylene...
Anyone on here mess around with machining of PE? Looking to do some work with LDPE, HDPE, or UHMW. The end product will be plumbing manifolds for water, so abrasion and impact resistance are no issue. The part will be in the presence of corrosive gasses, thus the use of PE. My question is, which is easiest to do machining on? I will be doing some drilling and tapping of holes, and that is about it really. Your insight is greatly appreciated!
Dirt_Devil is offline   Reply With Quote
Old October 7th, 2009, 01:16 PM   #2
KartRacer
Blowd up
KartRacer's Avatar
UHMW is easy to machine and cheap, but finish doesn't turn out the best. It's very stringy. I've machined much HDPE with good success. I can't say much about LDPE.
Old October 7th, 2009, 01:20 PM   #3
Bow_Extreme
Bow_Extreme's Avatar
UHMW is very easy to machine and tooling concerns are of no issue. Drilling holes is very easy to do. You can tap UHMW but I would use helicoil inserts if there is a fair amount of torque on the screw being used.
Bow_Extreme is offline   Reply With Quote
Old October 7th, 2009, 02:14 PM   #4
Just slow your tool down or you'll melt it and have a mess.
Old October 7th, 2009, 02:31 PM   #5
Disco Stocker
№ ℮ Ђ ώқ Θה ς├│ﺝ
Disco Stocker's Avatar
I do hdpe and I can do almost any thing with it. Just shoot any ? and line sizes.
Im more in the field for anti abrasion. I normally deal 4" or larger
Disco Stocker is offline   Reply With Quote
Old October 7th, 2009, 02:32 PM   #6
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Pretty much as said above. A finish pass can achieve nice finish though. Also, if going deep, use a peck method to keep from "packing" the tool with the material.
RIP FULLSIZE4LIFE
Old October 7th, 2009, 08:54 PM   #7
Dirt_Devil
Dirt_Devil's Avatar
Thanks for the input guys... I am most concerned about tapping the holes and getting a clean cut on the threads so they don't leak. I have enough material that I will have a couple chances to mess up a couple times though.
Old October 8th, 2009, 11:19 AM   #8
jeepnxj96
jeepnxj96's Avatar
We Machine Quite A Bit Of Hdpe, Uhmw,nylon,delrin And Other Plastics, By Far Hdpe Is The Best For Machinability
Old October 8th, 2009, 01:00 PM   #9
catman
done haulin
catman's Avatar
Would nylon work? I (my work) have a line of nylon manifolds for plumbing and injection mold machines.....
When its all said and done I really don't care what people think about me...
catman is offline   Reply With Quote
Old October 8th, 2009, 01:13 PM   #10
MTUCJ7
Never Wheeled Before
MTUCJ7's Avatar
HDPE ftw.
MTUCJ7 is offline   Reply With Quote
Old October 8th, 2009, 01:21 PM   #11
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
I would definitely stay away from UHMW for anything with tapped holes in it. I don't have any experience with using it for manifolds but I would think that if there is any amount of pressure the threads might just rip out of it.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old October 8th, 2009, 03:43 PM   #12
Dirt_Devil
Dirt_Devil's Avatar
Going with HDPE... Nylon actually breaks down in this application. Thanks again guys.
Page generated in 0.23114 seconds with 58 queries
