The LS Hunter Dakota - Page 66 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2014, 12:02 PM   #1301
2" bore, 8" stroke (1x3.14x8)
25.12 in^3 to extend
2" bore, 1 1/8" rod dia
((2-1.125)/2)x3.14x8=10.99
10.99 in^3 to retract.
1/2 turn difference my ass
Old April 30th, 2014, 12:03 PM   #1302
joescamaro67
joescamaro67's Avatar
Originally Posted by Mr. Beefy View Post
Waiting on that text right now.
$600 if you include the adapter, fittings, hoses. I already had the new pump, and tabs.
Trust me if I could of swung the PSC kit I would have
My new air bumps, cans, and inner air locks are on the way too! Scratch that
Oh wait my garage roof looks like this
I dont see tar paper yet so I`d run it another year
joescamaro67 is offline   Reply With Quote
Old April 30th, 2014, 12:05 PM   #1303
Lousypirate
Whoop Whoop
Lousypirate's Avatar
So would the center of the wheel rotation shift as you turn to lock in the push stroke to return it to center the other way? Couldn't you technically run out of steering at that rate? I haven't researched that much about steering valves...
shouldn't you divide that by two since you are effectively using the midpoint of your stroke as tires pointing straight?
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old April 30th, 2014, 12:12 PM   #1304
no
Old April 30th, 2014, 12:16 PM   #1305
hoses, adapter fittings, new ps pump, orbital, cylinder, tabs? If so for $500, you're awesome
I have a touch more then that into mine. And that's adding the steering column, wheel, and cooler on top of what you listed.
Old April 30th, 2014, 12:21 PM   #1306
Since they list the orbital valve and cuin/rev rating on their website the only real difference in cost I see is $100 for the TSC cylinder vs $330 for their DE cylinder and 1 set of hiems for the difference in Tie rod configuration.
Not that I've been looking at all
http://www.surpluscenter.com/Hydraul...CYL-9-6845.axd
This cylinder cuts it to $87 plus $40 for 7/8 x 3/4-16 rod ends with jam nuts.
Old April 30th, 2014, 03:48 PM   #1307
Tab
Tab's Avatar
Are you putting inner airs inside your new beadlocks?
Old April 30th, 2014, 03:50 PM   #1308
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Hopefully not but it's on the table. I'm not buying them just yet.
Old April 30th, 2014, 07:37 PM   #1309
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I was curious as to the actual difference in my steering so i checked tonight....~3.3 one way and ~2.75 the other....until i actually set there and counted tonight i had never even noticed the difference.
I wouldn't call these type steering setups shit. Are you going to go race koh with it? No....Does it work great for recreational wheeling? Hell yes. I have for sure less than 500$ in mine. Stock pump, fabric hose with reusable ends so it can be assembled and repaired on the trail no problem, tabs made from scrap steel, ect and it all works very well.
Old April 30th, 2014, 08:31 PM   #1310
I know beefy and the crowd he wheels with enough to know that slow steering will be dangerous for him
Old April 30th, 2014, 09:53 PM   #1311
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Big bird is my Canadian hero.
Sent from my Galaxy S4
Old April 30th, 2014, 10:02 PM   #1312
Grassman
2jz specialist
Grassman's Avatar
Cookie monster is a close second in my book
Old April 30th, 2014, 10:03 PM   #1313
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I maka da short shafta...
Cheap Thrills Off Road
Old April 30th, 2014, 10:51 PM   #1314
busyfixin
Balls Deep
busyfixin's Avatar
I have some super sweet double ended tie rod type cylinders on my hoopty, If you can figure out where the hell they came from, they could be a cheaper option.
Old May 1st, 2014, 07:11 AM   #1315
2 things, I didn't say it was a shit setup, I said "if he's wrong on the orbital again he'll have spent more than the PSC double ended system to have shit steering"(7 turns of the wheel to turn one way is shit.)
How is your orbital 7.6 in^3/rev one way and 3.99 in^3/rev the other direction(3.3 and 2.75)? Cylinder volume is easy to calculate, volume minus the rod is the volume the other way and your steering doesn't make sense to me if it's a closed system.
Old May 1st, 2014, 10:34 AM   #1316
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
How is your orbital 7.9 in^3/rev one way and 3.99 in^3/rev the other direction(3.3 and 2.75)? Cylinder volume is easy to calculate, volume minus the rod is the volume the other way and your steering doesn't make sense to me if it's a closed system.
I know what your saying....and i don't have an answer....all i can do is is count turns and that is what it comes out to lol
How did you get 7.9? It is 7.6 rated and (3.14x1x8) / 7.6 = 3.3
I know its not a big difference just curious
Old May 1st, 2014, 10:42 AM   #1317
crunchedtj99
longer line from one sid of the ram to the orbital? meaning more fluid to push? idk just thinking out loud
crunchedtj99 is offline   Reply With Quote
Old May 1st, 2014, 01:27 PM   #1318
BigBird
BigBird's Avatar
If the line were empty, that would be true, but both lines are full therefore length is negligible.
Old May 1st, 2014, 09:06 PM   #1319
crunchedtj99
true thought about that driving after lol.
Old May 1st, 2014, 10:26 PM   #1320
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Fixed it.
http://youtu.be/sxx_N0-32V0
Page generated in 0.50868 seconds with 84 queries
