The LS Hunter Dakota - Page 62 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2014, 01:03 PM   #1221
What year and model engine and powersteering pump? What size AN fitting is on that hose?
Old April 15th, 2014, 01:05 PM   #1222
Mr. Beefy
BFT!
Mr. Beefy's Avatar
97 dodge Dakota or Ram have both no idea what fitting
Sent from my Galaxy S4
Old April 15th, 2014, 01:06 PM   #1223
Mr. Beefy
BFT!
Mr. Beefy's Avatar
V6 and V8 same pump
Old April 15th, 2014, 01:09 PM   #1224
Output I take it?
Old April 15th, 2014, 01:10 PM   #1225
You need either a 16mm male oring fitting or an 18mm male oring fitting.
What's it measure?
Old April 15th, 2014, 01:11 PM   #1226
And what size an fitting is on that hose now?
Old April 15th, 2014, 01:17 PM   #1227
Mr. Beefy
BFT!
Mr. Beefy's Avatar
No idea that is a j something he said it was common and Napa could make the other side of it.
Old April 15th, 2014, 01:19 PM   #1228
Well without answers I can't help.
Old April 15th, 2014, 01:22 PM   #1229
Mr. Beefy
BFT!
Mr. Beefy's Avatar
He cut the pressure hose from my pump and put an end on it. He said well hope it holds... He is the one that wanted me to braze too fittings together.
Old April 15th, 2014, 01:32 PM   #1230
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I wouldn't put that on my vehicle. $.02
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old April 15th, 2014, 01:40 PM   #1231
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I'm pretty sure Algoma steel doesn't use the local plow shop for their hydraulic supplies.
Sling Choker, Beta Fluid Power, Raker Industrial Services...
They are all on this side of the ditch... Sling Choker is close to Rectors (Where the drive shafts be!)
Cheap Thrills Off Road
Old April 15th, 2014, 04:15 PM   #1232
bluminade
Bluminade Has Arrived
bluminade's Avatar
you can get reusable male and female fittings (field fittings) put one on your power steering hose and then the other on a hose to go to your valve. i would use a new power steering hose not the one that was already on the truck. i have done this a couple times when i could not get the correct fittings. if you need any info on this pm me your # and i will give you a call.
bluminade is offline   Reply With Quote
Old April 15th, 2014, 05:54 PM   #1233
The field fittings on the OE type p/s hose don't work well together. I tried it and had multiple issues. The sharp edges of the field fitting cuts the house apart. Without the steel of the hyd. Hose liner the OE hose can't last.
Including failure and fire.
I bought a new OE hose from the parts store, cut the crimp clamp off the pump end. Found a place that put hyd hose on it and crimped it for me. Said no warranties and didn't charge me. I have had zero issues with it.
Old April 15th, 2014, 06:59 PM   #1234
bluminade
bluminade's Avatar
i have done it both ways, it has worked in a pinch when i could not get any thing else. crimping them is always a better idea if you can get someone to do it, most places wont or cant legally.
Old April 15th, 2014, 07:47 PM   #1235
It took three shops to find someone to do it.....every old guy said no, last stop was a young guy. He didn't care.
Old April 15th, 2014, 08:05 PM   #1236
I have had field fittings work.............. and fail.
Old April 16th, 2014, 06:57 AM   #1237
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I ordered a -6 AN fitting for the pump and found some -6an fittings for the ram. Measured for lines last night steering should be done tomorrow.
Old April 16th, 2014, 12:58 PM   #1238
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Front axle now has breaks, orbital is mounted again, steering is burned in, getting lines made up on lunch today.
Tim got the rear of the truck wired and the winch.
Tonight pulling the trans to put the torque converter in it and a new tailshaft bearing.
It's coming together.
Old April 16th, 2014, 05:27 PM   #1239
BigBird
BigBird's Avatar
Unhappy
see update on other site...
Old April 16th, 2014, 05:42 PM   #1240
Grassman
2jz specialist
Grassman's Avatar
there is another site? gl4x4.org?
Page generated in 0.50832 seconds with 84 queries
