The LS Hunter Dakota - Page 58 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2014, 11:38 AM   #1141
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I would like to but with other trips I have planned it just doesn't work out. I'll still be wheeling that weekend just not at twisted trails
Old April 7th, 2014, 11:49 AM   #1142
Porter
Porter's Avatar
Default Hmmmmm
Originally Posted by crunchedtj99 View Post
that switch panel is awesome
Originally Posted by Carbon View Post
Great build Beefy! Crazy transformation.
x2
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old April 7th, 2014, 10:17 PM   #1143
snocross2xtremes
snocross2xtremes's Avatar
Lookin good
Old April 9th, 2014, 07:42 AM   #1144
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Spy photo?
Old April 9th, 2014, 08:08 AM   #1145
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Is that for real? Or Photoshop...
Cheap Thrills Off Road
Old April 9th, 2014, 08:11 AM   #1146
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I don't have a tube roller
Old April 9th, 2014, 08:43 AM   #1147
firehawk
Live Action!
firehawk's Avatar
But its made of tube and you roll it
Old April 9th, 2014, 11:03 AM   #1148
Need spring info.......
Put it at ride height and give me shock shaft showing numbers at ride height as well please.
16's in the front, 18's in the back correct?
Old April 9th, 2014, 11:14 AM   #1149
Mr. Beefy
BFT!
Mr. Beefy's Avatar
You will have it tonight. I worked too many hours last night, dad did some work and got the shock mounts tacked in.
Thanks for all the help Brandon
Edit - Yes 16's in the front getting 100% of the travel from them will be easy.
The 18's are in the back and only getting about 75% outta them
Old April 9th, 2014, 11:40 AM   #1150
I figured I'd document it here so I don't have to search through PM's if it's all wrong
Old April 9th, 2014, 12:14 PM   #1151
GMKLR50
Broke wheeler
GMKLR50's Avatar
just swap shocks front to rear, travel restrictions solved
GMKLR50 is offline   Reply With Quote
Old April 9th, 2014, 12:42 PM   #1152
I'm betting you won't get full motion from your driveshafts.
Old April 9th, 2014, 12:51 PM   #1153
Mr. Beefy
BFT!
Mr. Beefy's Avatar
The front has plenty. That's the reason to limit the rear
Sent from my Galaxy S4
Old April 9th, 2014, 12:51 PM   #1154
Is it installed yet to know?
Old April 9th, 2014, 12:58 PM   #1155
Why would it need to be installed to know?
Old April 9th, 2014, 03:53 PM   #1156
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I had one that was the correct length, it fit just fine at full droop.
Old April 9th, 2014, 07:39 PM   #1157
Mr. Beefy
BFT!
Mr. Beefy's Avatar
OK here we go.
Spring Inventory:
2 × 18" 300 #
2 × 16" 275 #
2 × 16" 225 #
2 × 14" 225 #
2 x 5.5" 90 #
Front of the truck with 18" 300 # compressed 2.25"
Rear with 16" 275 # compressed 1.75"
Front will need about 7.5" shaft showing rear only about 6" showing.
Edit - still need winch, fuel tank, radiator , torque converter and driveshafts.
Old April 9th, 2014, 07:40 PM   #1158
Grassman
2jz specialist
Grassman's Avatar
is that with tires at full pressure? or trail pressure?
Old April 9th, 2014, 07:44 PM   #1159
Mr. Beefy
BFT!
Mr. Beefy's Avatar
That was with them at 10psi
Old April 9th, 2014, 07:46 PM   #1160
Grassman
2jz specialist
Grassman's Avatar
guessing or did you check?
Page generated in 0.27309 seconds with 84 queries
