The LS Hunter Dakota - Page 45 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2014, 09:29 AM   #881
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I don't disagree with what your saying, all I'm saying is that he's running poly bushings 14" or so away from the engine, that bitch isn't going to move.
We have our drivetrain mounted on 4 poly bushings, all near the frame. So far, so good. We figured it would all flex (or not) together. It makes it easier to r&r the drivetrain.
Old February 21st, 2014, 09:37 AM   #882
That's what I was hinting at
Old February 21st, 2014, 10:23 AM   #883
I agree with the 3 point theory. However, mine is 4 pt.
Old February 21st, 2014, 10:33 AM   #884
I completely agree with the 3 point theory if the first 2 are actually going to move.....
Old February 21st, 2014, 10:43 AM   #885
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by Lousypirate View Post
I have a hard time picturing that much load going through the bolt, maybe over time.
You must have never seen him drive..
Old February 21st, 2014, 10:45 AM   #886
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by Mr. Beefy View Post
I can't drill that many holes accurately lets be honest here...
hahahahahahahahaha
Old February 21st, 2014, 12:10 PM   #887
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Originally Posted by bigblockford79 View Post
FWIW, the engine in my truggy used solid mounts to the frame. I then made cross braces between the frame rails under the trans and t-case. I then used a factory style rubber trans mount and used a poly bushing at the t-case. Transmission and t-case mounts were as close to the center line of the power train as possible so they were a supporting pivot point. Worked great for my rig, I also had the frame rails boxed. My cross members were bolt in at the frame, but were rigid mounted and both ends of the frame had welded rectangular tubing instead of the factory riveted style. The frame was very rigid.
This setup is what i was going to shoot for with my engine swap.
I am watching all this with curiosity. Physically getting my new drive train mounted in my rig is the most daunting task of my whole swap.
Old February 21st, 2014, 03:34 PM   #888
1 ton tj on 40's
1 ton tj on 40's's Avatar
found a secret pic of the new look.
Old February 21st, 2014, 03:40 PM   #889
Gogolen
He's making it a ranger truggy?
Gogolen is offline   Reply With Quote
Old February 21st, 2014, 05:20 PM   #890
Grassman
2jz specialist
Grassman's Avatar
Yup, expensive and difficult when you start with a Dakota too
Old February 21st, 2014, 08:27 PM   #891
chevotass
chevotass's Avatar
monster mud mega truck!!
Old February 21st, 2014, 08:30 PM   #892
tonka toy
It's got a HEMI!
tonka toy's Avatar
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old February 21st, 2014, 08:41 PM   #893
chevotass
chevotass's Avatar
looks like a slight toe in problem. other than that shes good to go
Old February 21st, 2014, 11:02 PM   #894
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Started measuring for links tonight.
Sent from my Galaxy S4
Old February 22nd, 2014, 01:43 AM   #895
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Your cordless impact needs a little female help...
Cheap Thrills Off Road
Old February 22nd, 2014, 03:50 AM   #896
No matter what you do ....... It's still a dodge.
Old February 22nd, 2014, 04:10 AM   #897
BigBird
BigBird's Avatar
Did you get your 8 hours of sleep already??? Hahaha
Old February 22nd, 2014, 11:00 AM   #898
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Fawker
Old February 22nd, 2014, 11:52 AM   #899
disturbedsledneck
disturbedsledneck's Avatar
disturbedsledneck is offline   Reply With Quote
Old February 22nd, 2014, 05:31 PM   #900
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Finished up the motor mounts.
Figured I could shave some weight.
Single shear.
Page generated in 0.38009 seconds with 84 queries
