The LS Hunter Dakota - Page 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2014, 12:14 PM   #861
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by Mr. Beefy View Post
What is this crazzieness about separation at the trans mount?
Long story short, you need to use a single bushing in the center with rigid mounts at the frame, not a crossmember ridgid mounted to the trans with bushings on the outer ends where it mounts to the frame. Outboarded bushings put lots of stress on important things like the transmission case.
Old February 20th, 2014, 12:15 PM   #862
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Roger. Never knew that.
Sent from my Galaxy S4
Old February 20th, 2014, 12:57 PM   #863
In this case, his engine is mounted damn near rigid so the center bushing will allow more twist than the engine itself. The idea is for them to be able to twist together so one is not fighting the other.
Old February 20th, 2014, 01:54 PM   #864
bbaXJ
Yooper In Training
bbaXJ's Avatar
3 points form a plane, 4 points add an extra constraint that will in turn add extra stress where it's not intended. The motor mounts are there to prevent twist, the trans mount is there to support it along the length of the vehicle, just like every stock application.
Old February 20th, 2014, 02:01 PM   #865
Thanks for the lesson. If the engine doesn't move but the back end is allowed to move where does the twist end up?
Old February 20th, 2014, 02:30 PM   #866
bbaXJ
Yooper In Training
bbaXJ's Avatar
The engine will still move, so will everything else unless you hard mount it all and prevent any chassis twist. There will always be stress on these parts and will pretty much always be movement. Will it fail catastrophically by mounting the trans bushings outboard? Probably not. Will it add unnecessary stress to the system? Yep. That's the only point I'm trying to make. It can work fine and has for many people, but it's not the "right" way to do it.
Old February 20th, 2014, 02:37 PM   #867
I don't disagree with what your saying, all I'm saying is that he's running poly bushings 14" or so away from the engine, that bitch isn't going to move.
Old February 20th, 2014, 02:46 PM   #868
bbaXJ
Yooper In Training
bbaXJ's Avatar
From what I've seen of Beefy's driving, EVERYTHING moves
Old February 20th, 2014, 02:47 PM   #869
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I can't wait to actually get some real travel outta the shocks I got from you.
Old February 20th, 2014, 03:39 PM   #870
From what I've seen of Beefy's driving, EVERYTHING BREAKS
fixered
Old February 20th, 2014, 05:15 PM   #871
Cool parts peddler
Ironman Offroad's Avatar
His motor mount bolts at the block are in double sheer.
This is unlike what most of us are used to seeing on our projects.
There is a huge boss on the block the bolts pass though and the mount straddles this boss.
I am not sure his original design is that bad.
I would put the frame end mounting points inside the frame if it was me.
Old February 20th, 2014, 05:52 PM   #872
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
You should just build a buggy. No one would gripe at you then.
Old February 20th, 2014, 05:52 PM   #873
1 ton tj on 40's
1 ton tj on 40's's Avatar
sounds like a part out
Old February 20th, 2014, 06:18 PM   #874
bigblockford79
Big Block Ranger
bigblockford79's Avatar
FWIW, the engine in my truggy used solid mounts to the frame. I then made cross braces between the frame rails under the trans and t-case. I then used a factory style rubber trans mount and used a poly bushing at the t-case. Transmission and t-case mounts were as close to the center line of the power train as possible so they were a supporting pivot point. Worked great for my rig, I also had the frame rails boxed. My cross members were bolt in at the frame, but were rigid mounted and both ends of the frame had welded rectangular tubing instead of the factory riveted style. The frame was very rigid.
Old February 20th, 2014, 07:53 PM   #875
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I'll take what's left of the cab...
Cheap Thrills Off Road
Old February 21st, 2014, 07:12 AM   #876
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Got nothing done on it last night
But the diesel is fixed
Old February 21st, 2014, 07:37 AM   #877
chevotass
chevotass's Avatar
buy a rzr
Old February 21st, 2014, 07:45 AM   #878
Grassman
2jz specialist
Grassman's Avatar
That's my plan
Old February 21st, 2014, 08:03 AM   #879
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I like golf carts
Old February 21st, 2014, 08:03 AM   #880
Mr. Beefy
BFT!
Mr. Beefy's Avatar
With roll cages
Page generated in 0.41606 seconds with 84 queries
