The LS Hunter Dakota - Page 25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2012, 09:32 PM   #481
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Found some hardcore 1%carnage on her yesterday...
Battery tray is loose
Old September 24th, 2012, 10:06 PM   #482
Grassman
2jz specialist
Grassman's Avatar
Wp wp wp
Old September 24th, 2012, 10:07 PM   #483
Mr. Beefy
BFT!
Mr. Beefy's Avatar
It's so bad I almost took a video of it
Old September 24th, 2012, 11:12 PM   #484
Ford forever
Bought another jeep
Pics or I call bullshit
Ford forever is offline   Reply With Quote
Old October 4th, 2012, 07:15 AM   #485
Mr. Beefy
BFT!
Mr. Beefy's Avatar
So I attempted to wire my fans last night
*Weird I'm kinda leery of messing with them now*
(Previous setup)
One fan is wired to a switch in the cab, other is wired direct to battery with a reostat inline that controls when it turns on and off via a probe in the radiator.
New idea
Cut the main lead on the switch fan and hook to the main power for the reostat. This should give me the ability to turn on and off both fans.
Correct?
That was my thoughts but the truck hit about 200 last night and the second fan had not kicked on yet I could not reach the reostat to try to play with the temp sensor on it as it was pouring down rain and 12:00 a.m.
Old October 4th, 2012, 08:17 AM   #486
hamsmotorsports
hamsmotorsports's Avatar
So you are running the power to the switch through the reostat? Then both fans off the switch. So if you turn the switch on it won't get power until the stat reaches temp and puts power to the switch.
hamsmotorsports is online now   Reply With Quote
Old October 4th, 2012, 08:19 AM   #487
Mr. Beefy
BFT!
Mr. Beefy's Avatar
That's the thought I'm thinking that the thermostat didn't open last night. We'll see how it does in canada worst case I can wire the fan direct for this weekend and just pull the fuse.
Old October 4th, 2012, 08:44 AM   #488
hamsmotorsports
If it is wired like I said both fans should come on at the same time. Only one switch correct
Old October 4th, 2012, 09:19 AM   #489
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Correct.
The way I have it wired is like this.
Sorry just re read your post, this is how it's currently wired.
This should make it so the passenger side fan turns on first. And once the radiator heats up it will kick on the second fan automatically.
I think
Old October 4th, 2012, 09:25 AM   #490
Grassman
2jz specialist
Grassman's Avatar
What is the tv for in that diagram?
Old October 4th, 2012, 09:29 AM   #491
Mr. Beefy
BFT!
Mr. Beefy's Avatar
that is the reostat
Edit and I see I missed a ground on the right fan it also goes to frame ground.
Old October 4th, 2012, 10:01 AM   #492
hamsmotorsports
Ok with it like that looks like the stat is prolly not set right
Old October 4th, 2012, 10:09 AM   #493
Wasn't the stat all jacked up from using a gerber on it or something? Wire one of them to come on with key on and the other on a switch. If it doesn't stay cool with one, wire them both to come on with key on. Use relays, not direct wiring
Old October 4th, 2012, 10:10 AM   #494
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Kinda what I thought or it didn't get hot enough for the radiator to heat up.
Thanks for the help see ya this weekend
I want the ability to turn them off for water crossings (canada has some deep shit)
Old October 4th, 2012, 10:13 AM   #495
pull the relay if you need to or wire a switch inline with your key on power
Old October 4th, 2012, 10:18 AM   #496
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Good idea :-)
I'm no electrician by any means I need to go through this entire rig I could spend 3 weeks re-doing this shit
Thanks Brandon and Chuck
Old October 4th, 2012, 10:44 AM   #497
Porter
Porter's Avatar
Default Hmmmmmm
....shouldn't this thread be up to Revision X by now?
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old October 4th, 2012, 10:46 AM   #498
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Beta
Old October 10th, 2012, 10:50 AM   #499
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
Damn beefy!
I remember when you first lifted this truck and every one was Guiving you a load of crap.
It turned into a nice truggy!
Not pretty by any means but it doesn't need to be.
Very nicely done.
muddy maki is offline   Reply With Quote
Old October 10th, 2012, 11:04 AM   #500
Mr. Beefy
BFT!
Mr. Beefy's Avatar
It's not pretty?
Page generated in 0.34316 seconds with 84 queries
