LS2 mated to Th400 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 6th, 2009, 11:34 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default LS2 mated to Th400
whats required? my friends thinking about picking up a LS2 and dropping it in his 84 monte carlo. he has a Th400 and would like to keep the trans. i told him the torque converter spacing and pattern is different he doesn't seem to think so. he wants to keep his converter because he has some special variable pitch converter.
Old October 6th, 2009, 11:37 AM   #2
Tom
Because racecar
Tom's Avatar
The pilot on the converter is WAY different, so is the offset of the pads between the converter's face and flywheel. Bolt pattern is the same, but you will loose 1 bell bolt.
Old October 6th, 2009, 11:40 AM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
so what does he need to get. i know theres adapters out there just for this problem.
Old October 6th, 2009, 11:48 AM   #4
cruzer72
cruzer72's Avatar
Try this.
This flexplate is designed for use when bolting a GM LS-based motor to a TH350, TH400, 700R4 or 4L60OE transmissions.
http://www.summitracing.com/parts/HUP-HP4004/#
2015 Wrangler Unlimited
1985 S-Blazer 4 linked, 427ci
1963 Nova SS 350hp I6
1972 Monte Carlo
1993 Tracker 4:1 Case, 33" KM2
cruzer72 is offline   Reply With Quote
Old October 6th, 2009, 11:50 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well that looks like it'll work.
Old October 6th, 2009, 12:28 PM   #6
95geo
newbie
95geo's Avatar
you can use everythign as-is but you need the little $30 spacer for the converter pilot. I have just about this exact setup sitting in the barn and I used the LSx flywheel and the th400 converter. if you buy the flywheel it's the easiest way to accomplish the mating. I dont like the lack of bolts holding the trans on so I'm going to make a little angle piece so I can still clamp the top of the bellhousing down to the block.
Page generated in 0.15050 seconds with 41 queries
