4.3 S-series jimmy/blazers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2009, 10:59 PM   #1
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Default 4.3 S-series jimmy/blazers
took my gmc jimmy into the shop after my engine started to have what i suspected a rod knock,says he thinks its a cracked flywheel? Would that sound the same? anybody else ever have an issue with this as well?
98ZJ318 is offline   Reply With Quote
Old October 6th, 2009, 01:20 AM   #2
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
A cracked flexplate would sound similar to a spun rod bearing.
Old October 6th, 2009, 06:58 AM   #3
jbsjunk
Little Member
jbsjunk's Avatar
Yes, a cracked flexplate can make the same noise. Same with loose converter bolts.
Old October 6th, 2009, 08:25 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
it could be either. 4.3s seem to have a common problem of spun bearings if the oil level gets low.
Old October 6th, 2009, 02:14 PM   #5
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
thats the thing, the oil never got low or ran out,just dirty...i figured itd be loose bolts but he still thinks its a cracked flywheel so we'll find out in a week or 2
Old October 6th, 2009, 11:14 PM   #6
Yota Bill
remove the bellhousing inspection cover and spin the engine over by hand, and take a look...if the bolts are loose, you will see shiny metal around them, if the plate is cracked...well, you'll see a crack...
Page generated in 0.19388 seconds with 41 queries
