Thornbird Tire pressure for Silver lake - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old July 4th, 2006, 11:26 PM   #1
xlinkinpark2438x
03 Rubicon
xlinkinpark2438x's Avatar
Default Thornbird Tire pressure for Silver lake
i am going to silver lake sand dunes this weekend of the 8th and 9th and was woundering what i should put my tire pressure at i have tiny 29 inch thornbirds for now on a 93 YJ with the dinky 4 cylinder
xlinkinpark2438x is offline   Reply With Quote
Old July 4th, 2006, 11:27 PM   #2
BMFmike
meh.
BMFmike's Avatar
42 pounds
give or take a few psi.
Old July 4th, 2006, 11:32 PM   #3
xlinkinpark2438x
03 Rubicon
Originally Posted by BMFmike
42 pounds
the tire says max psi is 30
Old July 4th, 2006, 11:40 PM   #4
BMFmike
meh.
BMFmike's Avatar
But once you enter an ORV park, things change, and with your tires throwing sand, they will cool at such a fast rate, it is essential to have a high pressure
Old July 4th, 2006, 11:41 PM   #5
biohazardbill
The Biohazards
biohazardbill's Avatar
42 pounds
Ummmm no lol
8-10lbs probably.. maybe even a tad lower
biohazardbill is offline   Reply With Quote
Old July 4th, 2006, 11:42 PM   #6
biohazardbill
The Biohazards
Your on drugs..... low pressure.......
Old July 4th, 2006, 11:43 PM   #7
BMFmike
meh.
BMFmike's Avatar
Close, I think they are called hallucenigents, see, they even effect my spelling
Happy 4th
And yes, I run the ssr's at 6 to 8 psi with no beadlocks.
Old July 4th, 2006, 11:45 PM   #8
xlinkinpark2438x
03 Rubicon
I guess what i will do is go in at 25psi and then drop it down to about 8-9psi and see how it does from there
Old July 4th, 2006, 11:50 PM   #9
biohazardbill
The Biohazards
Each tire is different.. play around with it....when I ha my YJ I ran the rear around 1-2 lbs less than the front due to the weight difference...... if you go to low... go to David Allen Racing and air back up :)
Old July 5th, 2006, 12:36 AM   #10
Renegade II
Coil springs are for pens
Renegade II's Avatar
I run the boggers on my CJ5 at 3-4 PSI up front and 1-2 PSI in the rear if the sand is really dry, 6/4 if its damp.
Old July 5th, 2006, 12:42 AM   #11
Mclovin
"The Situation"
Mclovin's Avatar
U're no fun.. Once u get into the pit area. air down. dont even try to go out wit anything over 15.. you'll just get stuck on the entry rd and cause a back up and everyone will hate you, call you bad names, moon you, and throw things at you
Old July 5th, 2006, 06:54 AM   #12
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
you do that and you WILL get stuck on the entry road. I have 33" thornbirds, and I run 1/2 to 1 psi. I was running b/t 8-10 and they still dug in a lot, not as much as 25-30, but they still dug in.
As low as you can go, or as low as you feel safe going....it takes a lot to make them thornbirds squat. have fun!
gotsand? is offline   Reply With Quote
Old July 5th, 2006, 10:37 PM   #13
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I would suggest just buying new tires...........but if that is out of the question 5-9psi should work. Tbirds have stiff sidewalls and need to be run at lower pressures. Especially with your 4cyl.
Old July 5th, 2006, 10:44 PM   #14
FlatFender
Tap Tap Splat
FlatFender's Avatar
Ive said it before, and Ill say it again. Do NOT go on the dunes without first checking your Muffler Bearings. Also, top off your blinker fluid.
Old July 5th, 2006, 11:18 PM   #15
xlinkinpark2438x
03 Rubicon
i dont want to goo too low where the bead might break
Old July 5th, 2006, 11:23 PM   #16
xlinkinpark2438x
03 Rubicon
i just checked the blinker fluid and it is low soo ill need to fill that up and as far as the muffler bearing goes it looks like i am going to haft to cut out the cherry bomb out.. i had to replace the radiator belt too
Old July 5th, 2006, 11:38 PM   #17
Mclovin
"The Situation"
Mclovin's Avatar
Ive said it before, and Ill say it again. Do NOT go on the dunes without first upgrading your Muffler Bearings to sealed roller units. Also, top off your blinker fluid with full synthetic.
fixed it for ya..
Old July 5th, 2006, 11:39 PM   #18
Mclovin
"The Situation"
Mclovin's Avatar
with a stiff sidewall it will take more to pop it. just dont try to be D.E. jr out there..
Old July 9th, 2006, 06:15 PM   #19
DeltaCavXJ
BCT made me hate Oreos!
Default blondestar
sounds like you guys use blonde star alot also u wanna be carefull not to run to high of RPMs u could run the timeing belt for the windows of track and that could cause a fire! lmao
DeltaCavXJ is offline   Reply With Quote
Page generated in 0.33541 seconds with 80 queries
