97 transfer case question/problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2009, 04:03 PM   #1
axxdet
axxdet's Avatar
Send a message via Yahoo to axxdet
Default 97 transfer case question/problem
its a 231 behind a 360 and when i give it gas the shift lever moves up, so i got under neith the truck had a buddy of mine tap the gas and the whole transfer case jumped off the cross member about three inches, it doesnt appear to have holes where something should bolt it down to the cross member, are there some other bushings that might have worn down, should i bolt it down to the cross memeber? thanks
axxdet is offline   Reply With Quote
Old October 5th, 2009, 04:31 PM   #2
PavementPounder
PavementPounder's Avatar
If it wasn't bolted to the crossmember from the factory, then something needs to be replaced.
Look at the trans mount. It probably wore out and collapsed.
Old October 5th, 2009, 04:47 PM   #3
axxdet
axxdet's Avatar
well it's just setting on the rubber bushing there's no bolts that go through form the transfer case down through the bushing and into the cross member. is there a possibilty its not the orginal transfer case or cross member
Old October 7th, 2009, 06:57 AM   #4
mopar96
Get Some!!
mopar96's Avatar
Mine was doing the same thing. My trans mount was broke all the way across and was flexing the drive train and allowing the drive shaft to rub the fuel tank. Check that its only 25 bucks and easy to change. My shifter lever was also moving very excessively.
mopar96 is offline   Reply With Quote
Old October 7th, 2009, 03:26 PM   #5
axxdet
axxdet's Avatar
thanks , but it just seems it should be held down better then just that pos....
Old October 7th, 2009, 03:37 PM   #6
PavementPounder
It was.
12 years ago.
Old October 7th, 2009, 04:06 PM   #7
axxdet
axxdet's Avatar
lol yea true, but mmm... i'm thinking about putting some kind of brackets that sandwhich the two thogether, not tight, enough to allow room for some movement, just so it cant kick up like it is..
Old October 7th, 2009, 04:11 PM   #8
PavementPounder
If you just fix it with the factory part for $15-$20, it won't kick up like it is for another 12 years. There's no need to make this complicated.
Old October 7th, 2009, 04:14 PM   #9
axxdet
axxdet's Avatar
alright, thanks, never had this problem before... it's all so new to me...
Old October 7th, 2009, 07:33 PM   #10
dodgeboy
redneck truck club
dodgeboy's Avatar
like everyone said there easy to do... i had to replace the one in my old dakota after doing some reverse donuts in 4wd... it was alot of fun doing them until it broke though
dodgeboy is offline   Reply With Quote
Page generated in 0.27545 seconds with 53 queries
