7.3 oil pan leak. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2009, 06:11 AM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default 7.3 oil pan leak.
A friend of mines 99 7.3 is starting to leak, has anyone used por 15 and had good luck on a pan as opposed to changing that pain in the ass pan?
Old October 5th, 2009, 03:25 PM   #2
7.3X
Fullsize support vehicle
7.3X's Avatar
Por 15 WILL NOT seal the pan against leaks.
7.3X is offline   Reply With Quote
Old October 5th, 2009, 03:47 PM   #3
Bones
Bones's Avatar
there are a lot of temperary solutions, but they are just that; temporary.
Buy a pan, fiberglass the outside of it, then spend a weekend to do it right.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 5th, 2009, 03:57 PM   #4
butters
It curves to the left...
butters's Avatar
POR won't stop the leak, put por 15 on the new one before us install it, good luck its
not a fun job.
butters is offline   Reply With Quote
Old October 5th, 2009, 05:33 PM   #5
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
i seen a guy who got a bunch of jb-weld, mixed it painted the pan with it, and he said it is going strong with no issues.
you cam also cut out the cross-member, replace pan and weld cross-member back on
mideerslayer is offline   Reply With Quote
Old October 5th, 2009, 09:14 PM   #6
frdboy
frdboy's Avatar
Yep, just pull the motor and do it right. Then you can replace the turbo and pedistal orings and up-pipe gaskets at the same time.
Old October 6th, 2009, 02:27 AM   #7
Fraser
Fraser's Avatar
holy crap, you know por 15 is just a paint type thing right? if the hole isnt too crazy and you can get it clean, id run some jb weld on there to get by for awhile
Old October 6th, 2009, 12:34 PM   #8
Ggg
If it is leaking it is too late. Time for a new pan.
Ggg is offline   Reply With Quote
Old October 6th, 2009, 11:10 PM   #9
Yota Bill
if your pulling the pan, I would also suggest replacing the rear main, and resealing the cover behind the rear main, which the oil pan seals to...that one just recently bit me in the ass...there are also a couple o-rings on the oil lines to the injection pump that leak into the lifter valley, run out of a weephole at the back of the engine, and then drips off the corner of the oil pan near the starter, which makes it look like a pan leak, and those are a common problem.
Old October 15th, 2009, 12:22 PM   #10
The Nuge
Season's Here
The Nuge's Avatar
Send a message via AIM to The Nuge
I would replace it. Someone had jb welded or some jank crap on the bottom of the oil pan on my truck before I bought it. You may as well fix it before it blows out while your going down the highway 1.5 hours from home.
The Nuge is offline   Reply With Quote
Page generated in 0.22760 seconds with 53 queries
