strange 9" third with a daytona pinion support - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 3rd, 2009, 03:29 PM   #1
joe_jeep
welfare wheeler
joe_jeep's Avatar
Default strange 9" third with a daytona pinion support
i need to swap the pinion yoke on a strange 9". it has the daytona pinion suport and a detroit.
this would have a solid pinion shim kit, not a crush collar correct? i thought you had to run a solid pinion shim kit.
no crush collars on daytona supports right?
any problems in swapping yokes i need to know b4 i swap them?
thx
Old October 6th, 2009, 02:14 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The Daytona support is a bit thicker so a standard yoke will need to be recessed for the nut to fit (to catch enough threads).
You can use a solild spacer or crush sleeve with the Daytona.
Page generated in 0.17304 seconds with 29 queries
