06 F-350 won't move - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 3rd, 2009, 07:08 AM   #1
Frank01TJ
Frank01TJ's Avatar
Default 06 F-350 won't move
Hey guys heres the story. I am in Iraq so bear with me. My wife was driving my 06 1 ton yesturday, stopped at her friends house, got back in the truck and she said "It felt like the brakes were locked". She said it would move a little, and "acted" like it wanted to move. I am not there so no i haven't checked anything. She said the tranny fluid looked good. I can not confirm this. Any ideas. The thing has a warranty, that i bought when i purchased the truck, so I am not worried about the cost. I am just a little curious if this sounds common to anybody??
Frank01TJ is offline   Reply With Quote
Old October 3rd, 2009, 07:18 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Is it an auto that won't go into gear? I've seen the fuses blow for the rear brake lights because of a short in the trailer harness that won't let the brake safety switch kick in to allow it out of park.
Old October 3rd, 2009, 07:32 AM   #3
Frank01TJ
Frank01TJ's Avatar
I should have been more specific CC.
The wife said "It will go a little in reverse" whatever that means. Its a automatic. Since she said it will go in reverse i am assuming that the tranny will come out of park. Now, since it will only go in reverse that made me think of a couple things.
A: Could be the e-brake (since it holds better in forward than reverse): But she would know if she set the e-brake, 1 tons let you knwo when you are trying to set the e-brake.
B: Could be a tranny issue, because they do wierdness when they go out.
Old October 3rd, 2009, 10:48 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
could be possible that the e-brake has seized in the applied position. idk if it has drums or discs out back but i have seen rear drums seize in the applied position causing the wheel to lock solid
Old October 3rd, 2009, 08:54 PM   #5
Offroadexpy
Rockin' the Stocker'
Offroadexpy's Avatar
Should have disc in the back.
The rear end didnt lock up did it?
If its 4x4 have her put in and see if it makes a differeence.
Offroadexpy is offline   Reply With Quote
Old October 3rd, 2009, 08:58 PM   #6
GrizzlySpitter
In the band!
this is very puzzling i have no real idea..i would call in someone who is at least a tech and have them check out tranny etc.
GrizzlySpitter is offline   Reply With Quote
Old October 4th, 2009, 09:56 AM   #7
Bones
Bones's Avatar
I'm guessing you have a trans failure. It might only be the valve body, but it could easily be a stuck band.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 4th, 2009, 10:01 AM   #8
BIGBADCJ5
= Broncoholic =
BIGBADCJ5's Avatar
The brake is prolly stuck , try it in 4x4 low see what happens. The trans could not have a stuck band it is almost new.
BIGBADCJ5 is offline   Reply With Quote
Old October 4th, 2009, 10:04 AM   #9
Bishop
Bishop's Avatar
it may be very unlikely but never rule anything out because its a new part or the truck isn't very old. weird shit happens all the time.
Old October 4th, 2009, 10:07 AM   #10
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yeah bones must be wrong its not like he works on these everyday may or may not be but im sure he has seen newer trucks with less miles with that failure otherwise he would have not brought it up.
Old October 4th, 2009, 10:28 AM   #11
BIGBADCJ5
= Broncoholic =
BIGBADCJ5's Avatar
Must be a PSD then they have all the problems, I thought Ford Super Duties were good trucks
Old October 4th, 2009, 01:08 PM   #12
Frank01TJ
Frank01TJ's Avatar
True the truck isn't old, but it does have 122000 miles on it.
Iam not ruling anythign out yet. I am deployed so its hard to answer some of your questions. My wife is not the most mechanical person so i say things like "does it hesitate" or "does it feel like the trans is slipping" and she goes, "huh".
But what i said earlier is what i know, it will reverse, but struggles going forward. I will have her try it in 4 low. See if that makes any difference. I don't think the brakes are stuk or anything, and the brakes looked goot when i bought the truck 3 months ago.
I will post anythign new that i find out. she is going to take it in tomorrow. Thanks for the help guys, If you think of anything new for me to have her try jsut let mw know.
Old October 4th, 2009, 02:13 PM   #13
hosejockey4506
Visiting Admin
where is the truck maybe some one could go look at it on here if its close
Old October 4th, 2009, 02:28 PM   #14
Frank01TJ
Frank01TJ's Avatar
yea, My wife moved back to NC from MI about 3 weeks ago. I know someone would be more than willing to go look at it, If it was close.
At least the truck made the trip while totein the boat before it shit on itself huh
Old October 14th, 2009, 02:10 PM   #15
Frank01TJ
Frank01TJ's Avatar
Update for those who care :
Passenger pads got so bad one fell the fukc out.
caliper got ground so damn thin it started pissing fluid all on itself.
That is the reason the truck wouldn't move. I am simply astonished at how the wife didn't notice a fucking brake pad missing. Or the fact that brake fluid was pissing on the tire. Please excuse me while i go punch myself in the face.
Old October 14th, 2009, 04:23 PM   #16
ChevroletBowtie
Guest
Posts: n/a
Go home and fix it.
Old October 14th, 2009, 04:29 PM   #17
Pokerob
hug life
Pokerob's Avatar
Originally Posted by ChevroletBowtie View Post
Go home and fix it.
your a fucking retard
Claytonfrnk,
thank you for serving
Old October 14th, 2009, 05:41 PM   #18
camccardell
tiger blood
camccardell's Avatar
chevroletBowtie... go fukc yourself with a broken pussy ass beer bottle you fucktard.
The dude is in IRAQ you dumbass.
x2 on the thanks for serving Claytonfrnk
don't feel bad, I've had to tell my wife that the suburban wouldn't start. She drug me out of bed on a cold winter morning to go look at it and the dang gas gauge was below the E.
What can you do? just shake your head...
Glad the problem was found and isn't gonna cost ya a ton.
Old October 14th, 2009, 05:59 PM   #19
capone
capone's Avatar
Go home and fix it.
You are a DICK
capone is online now   Reply With Quote
Old October 15th, 2009, 02:16 PM   #20
Frank01TJ
Frank01TJ's Avatar
Go home and fix it.
Cheveroletbowtie i stayed in the Military to defend your right to be a asshole. So i am glad to see that you are taking full advantage.
Thanks for the support from everyone else. We all appreciate it when those at home are gracious. Don't worry about this bowtie ass. He is probably still popping his pimples in his mothers mirror.
Page generated in 0.42819 seconds with 83 queries
