just bought a mustang runs funny - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 1st, 2009, 08:51 PM   #1
mudrunner456
mudrunner456's Avatar
Default just bought a mustang runs funny
picked up 87 mustang 5.0 5 speed the body isnt the greatest but it runs good, sorta. it idles fine and drives good but when i floor it the car will take off but once it hits about 3500 rpm it falls right on its face. Let off the gas a bit and it picks right back up. Only messed with it for a few minutes so as far as i know i could be anything. The exhaust stinks bad like old gas so im hoping to get it out and put fresh in it will take care of it. any other suggestions?
mudrunner456 is offline   Reply With Quote
Old October 1st, 2009, 08:57 PM   #2
rentalrider
rentalrider's Avatar
Nice. I love those old fox body 'stangs. I have and '86 5.0HO in my jeep cj and have an '89 freshly dipped, waiting for me to decide what heads, etc I'm gonna put on it. You might want to use the mustang forums after you try fresh gas and the other obvious fixes. They've been really helpful to me when chasing gremlins. If you need anything, shoot me a pm and I'll point you towards the forum I used. Post pics up!
Old October 2nd, 2009, 01:16 AM   #3
Big Bad Black X
Fuel pump is my bet. Make sure you clean out the fuel tank if you end up putting a new one in. Find someone to let you use a fuel pressure gauge, you can easily tap into the schradder valve on the fuel rail. If you cant find one you can borrow that you can see while driving you may have to have a buddy ride under the hood while you floor it and watch the gauge lol. I had to do this once, long story, and yeah, bad idea lol.
Big Bad Black X is offline   Reply With Quote
Old October 2nd, 2009, 06:41 AM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Check engine light on?
I'd check the MAP sensor, TPS sensor, and the condition of the plugswires/wires/cap/rotor.
Old October 2nd, 2009, 06:50 AM   #5
davidkassie
davidkassie's Avatar
the ignition coil likes to break down at higher rpms, just a thought!
davidkassie is offline   Reply With Quote
Old October 2nd, 2009, 07:19 AM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
Take rubbing compound and place it on the blue oval part of the vehicle. Rub vigorously until removed. Place GM logo in its place. Car should run ok now.
Just kidding, they are cool cars. I would drain the old fuel and put some fresh stuff in. I would also change the fuel filter. Next place I would look would be fuel pressure.
Good luck.
Old October 2nd, 2009, 12:33 PM   #7
Big Bad Black X
New filter is a good idea, I would start there if fresh gas didn't help. Easy and it probably needs it anyway.
Old October 2nd, 2009, 06:37 PM   #8
mudrunner456
yea just ut in the fresh gas, gotta go run it. got a pressure gauge gonna check that to. what should it have for pressure?
Old October 2nd, 2009, 11:38 PM   #9
Nuggets
I fix stuff!
Nuggets's Avatar
Off the top of my head I'd say 35-40 psi. Test in line off the test port. Test port is located on the fuel rail over top of the injectors. Sticking a screwdriver in the shrader valve of the test port and watching fuel spray out is not a confirmation of acceptable fuel pressure.
Fords use their own size test port on the fuel rail. If you have a standard pressure tester, you will be out of luck.
Old October 2nd, 2009, 11:47 PM   #10
1978f-150
village idiot
1978f-150's Avatar
id check the fuel pressure regulater fuel pump or the filter i had similer problem in my 79 hatchback when i did the injection swap
1978f-150 is offline   Reply With Quote
Old October 8th, 2009, 06:49 PM   #11
Big Bad Black X
Make sure you watch teh fuel pressure at higher RPM under load where you had a problem. When my 5.0 thunderbird had a high RPM miss it showed good fuel pressure till it was under load and RPM came up and the fuel pressure just sank after a certain point.
Page generated in 0.50357 seconds with 56 queries
