cj-7 frames all the same?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 26th, 2005, 06:42 PM   #1
trail junkie
Guest
Posts: n/a
Default cj-7 frames all the same??
I am doing a frame swap on my cj-7, got everthing switched over except the fiberglass body with no problems. I set the body on and some of the mounts are off by inches. I thought cj-7 frames were all the same so my ? is was this frame or my junk frame modified. I am just curious to find out pretty sure I can still make this frame work, worst comes to worst torch and welder:tonka:
Old November 26th, 2005, 06:53 PM   #2
biohazardbill
Guest
Posts: n/a
U sure u didnt get a YJ frame?
Old November 26th, 2005, 06:59 PM   #3
trail junkie
Guest
Posts: n/a
My cj axles bolted right up! Ya I am sure I have parted out a couple cj and yj I can tell the diff.
Old November 26th, 2005, 10:08 PM   #4
clarkstoncracker
lol
clarkstoncracker's Avatar
What tub did you pull of that frame? Was it a CJ?
You would think you could see the old body mounts on the frame, if it was indeed modified..
Is this FG tub new?
and are we talking inches, or feet on the bolts not lining up?
Old November 26th, 2005, 11:58 PM   #5
PavementPounder
PavementPounder's Avatar
I seem to recall newer CJ's having more mounts than the older 70's CJ's for some reason. Otherwise, you don't know what you have, or someone did cusom work.
Old November 27th, 2005, 02:42 PM   #6
trail junkie
Guest
Posts: n/a
Its only about an inche, used fg tub from my jeep, with out moving stuff around the body will be 1/2 to 1 inch over to the driver side I think. I will get better details later, was pretty lit last night working on it and its at a budys house.
Page generated in 0.19895 seconds with 41 queries
