'98 S10 Blazer rear axles? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2009, 03:50 PM   #1
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Default '98 S10 Blazer rear axles?
My sisters truck had a problem with the pinion in the rear end coming loose. The first time didnt do any damage. But I put it back together with new stuff p on the pinion. But it still decided to spit a few gear teeth and now its pretty much destroyed. She said everything was fine until she heard somethng start crackling and then the rear locked up. Which she's lucky she was on a grated dirt road and only doing 30.
But she has the disk brake rear, and I cant find them for under $300. Which she cant afford right now. So I was curious if a drum brake rear would interchange without major problems? Like, is there a difference in brake line pressures betweeen the two? Anything of that nature.
Old September 30th, 2009, 08:43 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i have an axle from a 93 with drum brakes with 3.42 gears. all you would need to do is take off all of your brake components and swap them onto the new axle. only asking $150 for it.
Old September 30th, 2009, 08:45 PM   #3
BlzrNick
Built not bought
BlzrNick's Avatar
i will sell you mine but I have to get one from a ZR2 first. Might be a while
BlzrNick is offline   Reply With Quote
Old September 30th, 2009, 10:24 PM   #4
Rebel2345
Rebel2345's Avatar
Ahh, thats good to know. I'll send you a PM if we need yours.
Old September 30th, 2009, 10:43 PM   #5
beedle4
beedle4's Avatar
I dont belive the e-brake will swap.
Do a search on s10forum.com much more info to help ya...
Page generated in 0.19908 seconds with 38 queries
