water pump leak - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2009, 01:19 PM   #1
currdogg
currdogg's Avatar
Default water pump leak
HI, i just put my water pump back in and it leaks from the weep hole under the fan shaft. is this normal? do i need a new pump?
Should i shoot it with a .44?
currdogg is offline   Reply With Quote
Old September 30th, 2009, 01:23 PM   #2
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Why did you have it out?
IFS SUCKS is offline   Reply With Quote
Old September 30th, 2009, 01:26 PM   #3
currdogg
currdogg's Avatar
well, i took it out cuz it was leaking and i thought it would be the gaskets. so i took 'er all apart and did them with new gasket. it seemed fine when i let it run a bit when i finished it, but today i let it run a lil longer and found the peeing out the weep hole. i dont know crap from crayons, this is my first time even seeing a water pump!!
Old September 30th, 2009, 01:28 PM   #4
Bishop
Bishop's Avatar
its junk. thats why that hole is there. if its leaking from there, it needs replacement.
Old September 30th, 2009, 01:28 PM   #5
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Replace it!
Old September 30th, 2009, 01:29 PM   #6
currdogg
currdogg's Avatar
Thank you.
Page generated in 0.32342 seconds with 41 queries
