350 TBI-lack of power issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 29th, 2009, 10:09 PM   #1
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
Default 350 TBI-lack of power issue
I have an 87' 3/4 4x4, it has a TBI injected 350 with a SM465 trans. The truck seems to have plenty of power empty, but when I put my trailer behind it, it's really is doggy. Even with just the empty trailer. I do have an intermittent check engine light. The truck seems to stumble a bit between 35-45 mph even when it's empty. Thanks for any advice or ideas.
Mijeeper CJ 7 is offline   Reply With Quote
Old September 29th, 2009, 10:34 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
start by finding out what the check engine light is on for. you can jumper 2 pins on the obd test connector to get a flash code for all trouble codes. this will be pins A and B which are the top 2 on the right side of the connector. you will get a code 12 first then any trouble codes after.
Old September 29th, 2009, 10:35 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
http://www.extreme-check-engine-ligh...%20Decoder.htm heres how to do that with a list of codes
Old September 30th, 2009, 04:12 PM   #4
Mijeeper CJ 7
thanks I'll start there
Page generated in 0.12098 seconds with 35 queries
