transfer case questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 29th, 2009, 11:04 AM   #1
musil
musil's Avatar
Default transfer case questions
the v8 swap hit a snag last night, i wanted to try and use the jeep t case behind my 700-r but the splines are different, what other options do i have for a t case that would make my stock speedo work, the s10 t case i have is for a mech. speedo. any help would be great.
musil is offline   Reply With Quote
Old September 29th, 2009, 11:10 AM   #2
Pokerob
hug life
Pokerob's Avatar
what jeep t-case? d300?
google it, this is what i came up with
http://www.novak-adapt.com/catalog/kit_137.htm
Old September 29th, 2009, 11:49 AM   #3
PavementPounder
PavementPounder's Avatar
If you have an S-10 drivetrain, you may have another problem. Does your S-10's 231 have only 5 mounting studs on the front of it? All the Jeep and other NP cases have 6, which is the standard NP pattern. The S-10 is the oddball.
If this is the case, you will need another transfer case adapter for your 700r4 that has 4 holes on the trans side and 6 on the t-case side. Any full-size truck application with a 700r4 and a 208 or 241 will have the correct adapter, but there could be differences in factory clocking. I know my 208 in my 87 Suburban wth a 700r4 is clocked way the hell down.
Is it a 27-spline input that you're looking for? Later Chevy trucks with driver-drop front diffs should have transfer cases (like a 241) with the 27-spline input.
Really going to need to know what you're trying to swap the driveline into, also.
Old September 29th, 2009, 01:30 PM   #4
musil
musil's Avatar
the driveline is out of an 84 subburban 350 w a 700r4 i have the adapter plate for the s10 tcase but its mech. speedo, so a t-case from a fullsize truck thats driver drop will work as well?? i'm trying to make my speedo work as easlily as possible, the jeep is 99 XJ it had a 4.0 with an auto tranny
Old September 29th, 2009, 01:33 PM   #5
PavementPounder
In that case, I think what you want is a driver-drop Chevy 241. I don't know how the speedo is fed on one of those, though.
Its probably time to get this thread moved to Chevy Tech since the problem is almost all non-Jeep.
Old September 29th, 2009, 04:56 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Take rear half of jeep 231 case bolt onto front half of the chevy 231 case and done!
Page generated in 0.20595 seconds with 41 queries
