Evolution of an s10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 28th, 2009, 02:41 AM   #1
Jordank520
Jordank520's Avatar
Default Evolution of an s10
I started out with a 2000 2wd s10 4.3l
heres it with a 3" lift
here it went to 7" of lift on 31x10.5's
then 14" total lift SFA swap on 33's
now under it is a Dana 30 from a 91 jeep wrangler, 4-8" drop pitman arm for a grand Cherokee and stock yj steering linkage
np205 divorced t-case from a Ford f250, custom cross member, and shift linkage
s10 leaf springs, with home brewed cross members.
front d shaft is out of the rear of a scotts dale, the rear d-shaft is a ford bronco front shaft cut down and re welded with an s10 rear yoke.
Jordank520 is offline   Reply With Quote
Old September 28th, 2009, 03:16 PM   #2
sandman86
sandman86's Avatar
got any shots of your front suspension?
sandman86 is offline   Reply With Quote
Old September 28th, 2009, 07:24 PM   #3
Jordank520
Jordank520's Avatar
Yes, I'll post them tonight
Old September 28th, 2009, 10:35 PM   #4
Jordank520
Jordank520's Avatar
cross member 3x3 1/4" square tubing
stock suspension taken off
axle set in place
transfer case and cross member
Old September 29th, 2009, 09:23 PM   #5
Westside Willy
Westside Willy's Avatar
Lookin good Jordan. The NP205 is hangin a little low ? Have any pics of side view ? What gearing in the axles?
Wheelin' pics ?
WW
Westside Willy is offline   Reply With Quote
Old September 29th, 2009, 10:58 PM   #6
Jordank520
Jordank520's Avatar
the transfer case couldn't really be set any higher, since the mounting holes are lower that the top of the transfer case. the axles are still 3:07 gearing. Its terrible but i plan on running full size axles coming next spring/summer. Every time I go out no one ever brings a camera. Like i have a picture of it on a sand hill but that about it.
Old September 29th, 2009, 11:08 PM   #7
wheelinblazer98
wheelinblazer98's Avatar
14" of lift and your only running 33s!?!?!
wish i could lift my 98 blazer, but no time or money
nice truck, looks great.
wheelinblazer98 is offline   Reply With Quote
Old September 30th, 2009, 12:08 AM   #8
beedle4
beedle4's Avatar
Looks nice.
Your on the s10 forum right?
Old September 30th, 2009, 01:07 AM   #9
Jordank520
Jordank520's Avatar
i only have 3;08 gearing i would be to hard to turn anything bigger. I really want to get 35's.
thanks for te compliments
yes s10 forum helped me so much
Old September 30th, 2009, 01:11 AM   #10
Jordank520
Jordank520's Avatar
more pics
Old September 30th, 2009, 01:35 AM   #11
beedle4
beedle4's Avatar
Yeah I thought I had seen it before...
Yeah you need 4:56 and some 35/36" meats!
Old September 30th, 2009, 09:23 AM   #12
Jordank520
Jordank520's Avatar
yeah, I was thinking 4:10s and 35's. I jsut cant decide if i want to run full size axles or re gear mine.
Old September 30th, 2009, 09:47 AM   #13
buttercr125
I work out
buttercr125's Avatar
Here is a pic of my 94 Jimmy on 39.5" Irok's. It has a 14 bolt rear and 10 bolt front for now. It has a tbi 350 with a 4l60e and a twin sticked dana 300. Thinking about selling though.
Old October 7th, 2009, 11:40 PM   #14
Jordank520
Jordank520's Avatar
looks good butter I need to regear mine so bad, I want 35's
Old October 12th, 2009, 05:57 PM   #15
MYSAS ZR@
MYSAS ZR@'s Avatar
Here are some of mine Before the SAS then after
Name:	IMG00029 00000.jpg
ID:	50884   Click image for larger version
MYSAS ZR@ is offline   Reply With Quote
Old October 12th, 2009, 08:23 PM   #16
badazzamc
Get Some
badazzamc's Avatar
looks good
Old October 22nd, 2009, 02:16 PM   #17
jdmdon
jdmdon's Avatar
jordan post some pics with your new 35" tbirds!
jdmdon is offline   Reply With Quote
Old November 8th, 2009, 01:14 PM   #18
Jordank520
Jordank520's Avatar
35x12.5 Tsl Thorbirds
Old September 27th, 2012, 06:26 PM   #19
Jordank520
Jordank520's Avatar
44/9" 4.56, om617/ ax15 swap on 37's
Page generated in 0.77483 seconds with 81 queries
