02 trailblazer 4wd ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2009, 01:25 PM   #1
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
Default 02 trailblazer 4wd ?
the 4wd won't engage on my wifes trailblazer, the lights above the dial aren't on either, besides the obvious checking the fuses, whatelse should I look at? I'm not real familiar with the 4wd on the tb, everything has worked before so there wasn't any need to work on it, other than routine maintenance.
jpr Jeremy is offline   Reply With Quote
Old September 27th, 2009, 03:07 PM   #2
Disturban
Disturban's Avatar
If I had to take an educated guess I would say maybe the T-case motor is shot/froze...common problem because people don't engage the T-case except in the winter then it goes a year without moving and they get stuck. I always put all my trucks in 4x4 at least once a week to make sure everything is working good and keep the T-case shifting freely. If the fuse is bad it could be because the motor is stuck or bad, but for sure check the fuse first and you may get lucky. Another problem is the switch but I think if they go bad the light will blink. Long story short the switch, T-case motor, fuse are your 3 main culprits.
Old September 27th, 2009, 03:17 PM   #3
frdboy
frdboy's Avatar
Pull the underhood fuse(s) for the TCCM (transfer case control module) for 30 seconds (could also be labeled ATCM or TREC) and reinstall then try it. They had issues "waking up" from sleep mode. If that fixes it it needs a new TCCM and a reprogram to keep it from happining again.
Old September 27th, 2009, 05:30 PM   #4
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
Thumbs up
thanks guys, that should get me in the right direction.
Old September 27th, 2009, 05:45 PM   #5
blownexploder94
Todd
blownexploder94's Avatar
Default 4wd
Old September 27th, 2009, 06:05 PM   #6
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
I'm guessing it's the motor, I pulled the fuse, waited, put it back in, now the indicator lights turn on, but when I turn the switch all of the lights turn on, then turn off and the service 4wd light turns on in the cluster.
Old September 27th, 2009, 06:34 PM   #7
blownexploder94
Todd
I would go get it scanned then and see what code it is actually pulling if it DTC B2725. there is another tsb on it to replace the transfer case shift control switch
Old September 27th, 2009, 06:58 PM   #8
joe_jeep
welfare wheeler
joe_jeep's Avatar
its the transfer case control module. i just changed mine in my wifes envoy. its a pain in the ass, and it aint cheap. its on the firewall. under the dash. all the way up, all the way left. about where your vin number is. check trailvoy.com. it has the info you need.
its new superceeded part number is #12590220
the one i took out was part number #15074733
its about $225.00 at the dealer, and about $95.00 to get it flashed at the dealer.
i found mine on ebay new for 130.00 but i got real lucky.
joe_jeep is online now   Reply With Quote
Old September 27th, 2009, 07:09 PM   #9
Shooter.McGavin
Shooter.McGavin's Avatar
I sold them for years. It's a pretty common problem they have. It's usually the motor.
Shooter.McGavin is offline   Reply With Quote
Old September 27th, 2009, 07:37 PM   #10
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
I'm hoping thats not it, I just put a grand in this damn thing this weekend, tires, brakes, 1 lower ball joint, and an allignment, when it rains it pours I guess! thanks for the info.
Old October 9th, 2009, 08:23 PM   #11
Ianstein
You might just want to check the switch. GM full sizes are notorious for having the selector switch go bad.
Ianstein is offline   Reply With Quote
Old October 9th, 2009, 08:27 PM   #12
badazzamc
Get Some
badazzamc's Avatar
it was the motor on my dads, His had the same problem last year
Old October 9th, 2009, 08:28 PM   #13
j_little3
Boris
j_little3's Avatar
new 4wd button
j_little3 is offline   Reply With Quote
Old October 26th, 2009, 08:09 PM   #14
lil_freak_66
Trolls off road club
lil_freak_66's Avatar
Send a message via MSN to lil_freak_66 Send a message via Yahoo to lil_freak_66 Send a message via Skype™ to lil_freak_66
i have a 4x4 trailblazer. i would suggest checking out www.trailvoy.com they have EVERYTHING you could need to know about them. if you cant find a thread on it(which is doubtful) make one in the proper subforum and im sure it will get some good hits as there is 20,000 some odd members
lil_freak_66 is offline   Reply With Quote
Old October 27th, 2009, 08:46 AM   #15
IFS SUCKS
I like trees
IFS SUCKS's Avatar
And if it has auto 4wd with auto trac II fluid,it needs to be changed every 50k
IFS SUCKS is offline   Reply With Quote
Old October 27th, 2009, 05:22 PM   #16
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
thanks for all the input, it turned out to be the switch in the dash, very easy fix.
Old November 18th, 2009, 11:12 PM   #17
lil_freak_66
yeah ive heard that happening a few times,its not common or rare...id say uncommon
Page generated in 0.40524 seconds with 75 queries
