4.2 rebuild kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2009, 06:33 PM   #1
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Default 4.2 rebuild kit
I got a '97 F150 with a rod knock. 4.2(256) with lower mileage, and has great compression, so I wanted to do a basic rebuild/re-ring. I'm hoping someone else might know of a cheaper place to find a kit than e-bay. I need everything in a master rebuild kit except the pistons. Any place more local that puts kits together? If not, where might I find an inexpensive kit?
Daddy Dan is offline   Reply With Quote
Old September 24th, 2009, 06:37 PM   #2
Swampdog02
Wakley Creek Wacos!
Swampdog02's Avatar
I have the reverse thing going on with my 4.2, no knock, but low compression.
I called Michigan Motor Exchange, in Westland.
I talked to Dan. The prices were decient.
They may be able to hook you up with the parts you need?
Westland :: (734) 595-8900
36391 Ford Rd.
Located between Wayne Rd. & Newburg Rd
Good Luck!
Swampdog02 is offline   Reply With Quote
Old September 24th, 2009, 10:35 PM   #3
Daddy Dan
SBF Nut
Daddy Dan's Avatar
sweet, thanks. I'll be out that way this weekend.
Page generated in 0.18053 seconds with 32 queries
