Heater Core leak, need help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2009, 05:09 PM   #1
bnmarlatt2004
BigBrutus
bnmarlatt2004's Avatar
Default Heater Core leak, need help
I have a 79 ford f-150 that has a leaky heater core. my problem is that the plastic piece that encloses the heater core is rivited together I was wondering if there were any easy ways to put a new core in.
bnmarlatt2004 is offline   Reply With Quote
Old September 24th, 2009, 10:01 PM   #2
Yota Bill
clcik this link:
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
sign on with your DL number
select year, make, model
select "repair"
follow path: Heating, Ventilation, & Air Conditioning > Heater Core > Removal & Installation
select which system you have
you didnt say which system you have, so thats the best I can do for you, except that the rivets you see are not to remove the heater core, the plates are held on with screws...unless someone had replaced the screws with rivets sometime in the last 30 years
Old September 25th, 2009, 07:43 AM   #3
sanman
sanman's Avatar
Better have your wife do it if you want it done right
sanman is offline   Reply With Quote
Old September 25th, 2009, 07:49 AM   #4
bnmarlatt2004
BigBrutus
it's a 2 wheel drive with no ac. I will check that site. thanks. Very funny sanman.
Page generated in 0.16527 seconds with 35 queries
