Need Chevy 350 tbi Help Guys! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2009, 07:46 PM   #1
osnapchuckie
learn after breaking...
osnapchuckie's Avatar
Question Need Chevy 350 tbi Help Guys!
Ive got a 92 Chevy with the 350 tbi, everythings stock on the thing. it starts and idles good. When i accelerate up to speed its all good sounds alil rough but ok. problem comes when i let off the throttle... it sounds like it wants to stall or choke... almost like a light backfire... and as soon as i touch the brakes it goes right to idle and is fine.
Thinking its the timing chain, but would like more insight.
If anyone knows costs on repairs or parts that could be the prob i would greatly appreciate it.
Also what forum would this question get posted in just so I know??
Thanks
osnapchuckie is offline   Reply With Quote
Old September 23rd, 2009, 07:59 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you said it was choking on heavy braking I would say you were missing a thrust washer off your cam. the trick is your engine shouldn't have roller lifters so that would be be the wrong thing to suggest. I am thinking along the lines of a lean miss backfire in the intake? does it sound like a bunch of pop,pop,pop....pop sounds untill you get up to speed? if so I could be a wiped out lobe or two on the camshaft?
Yetti
Old September 23rd, 2009, 08:01 PM   #3
Yetti
Yetti's Avatar
as for touching the brakes and it dropping to idle? that is you releasing the torque converter lock. it takes away the engine braking when you do that.
Yetti
Old September 23rd, 2009, 08:14 PM   #4
osnapchuckie
it doesnt make the noise when im accelerating just when i let off and let the engine slows itself down.
Old September 28th, 2009, 03:40 PM   #5
PavementPounder
PavementPounder's Avatar
Thanks
That would normally be Chevy Tech since there doesn't seem to be anything non-Chevy about your vehicle. No need to re-post it there. I reported your thread so that a Moderator who is actually paying attention will just move it.
Old September 28th, 2009, 05:59 PM   #6
osnapchuckie
Ok reset the timing back to zero. it takes off alittle better, but still when i let off the gas it chokes out and sounds like it wants to stall until it drops back down to idle then its fine....
Thinking maybe next is the EGR valve???
Also Would an exhaust leak cause problems like this to???
Old September 28th, 2009, 06:46 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
check engine light on?
Old September 28th, 2009, 07:24 PM   #8
osnapchuckie
Nope, and that works bc it was on after i did the timing and unplugged the electric timing plug, but it went right off after i turned the ignition off then back on.
Old September 28th, 2009, 08:22 PM   #9
Yetti
Yetti's Avatar
do me this, try pushing the gas down to full throttle for a second or so sitting in park. if it does the same thing(choking down) then you just found the problem. your cat is plugged.
Yetti
Old September 28th, 2009, 10:14 PM   #10
osnapchuckie
It still does that... I dont have a cat. Its straight pipes ran from the manifolds into two shitty flowmasters.
Old September 28th, 2009, 10:50 PM   #11
shredder70
Chillin with the top off.
shredder70's Avatar
sounds like you have a injector cutting out or bad.
shredder70 is offline   Reply With Quote
Old September 29th, 2009, 02:43 AM   #12
Disturban
Disturban's Avatar
Check the air idle solenoid on the TBI.
Old September 29th, 2009, 07:23 PM   #13
osnapchuckie
will do guys thanks
Old September 29th, 2009, 09:52 PM   #14
osnapchuckie
Disturban did you mean the idle air control valve???
Old September 29th, 2009, 10:11 PM   #15
Cartman
Can't lose with 42s
Cartman's Avatar
yeah dirty IAC would do it, so would a effed up VSS but its not throwing codes...tricky
Cartman is offline   Reply With Quote
Page generated in 0.25518 seconds with 68 queries
