1999 Tahoe bending pushrods? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2009, 04:17 PM   #1
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Default 1999 Tahoe bending pushrods?
my buddy at work has an odd problem with a 5.7 vortec in a taho turd. it has 150,000 miles and is just now in the habit of bending pushrods? anyone seen this lately?
Yetti
Old September 23rd, 2009, 05:08 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Same spot every time, or different locations? If it was in the same cyl, I would think something's keeping the valve from opening all the way. Does it run alright?
I've never run into this, kinda odd.
Old September 23rd, 2009, 06:10 PM   #3
Yetti
Yetti's Avatar
I was thinking something along the lines of a bent valve jammed shut. it would almost have to be. nothing generates that kind of presure to bend stuff like that? it bent one pushrod while cranking??? I think the head needs to come off.
Yetti
Old September 23rd, 2009, 06:19 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
I was thinking the same thing. Only one pushrod is bending? Would kind of rule out something in the cyl. Unless for some reason one of the keepers came out and jammed between the head and the retainer. Long shot for sure.
Old September 24th, 2009, 07:45 AM   #5
95geo
newbie
95geo's Avatar
carbon buildup on the stem causing it to hang up? if it did it at idle speeds then that kind of rules out the weak valve spring idea and tagging a piston at WOT and causing the stem to bend... it could already be bent... who knows... at 150k it could be anything.
Time for a rebuild!
Old September 24th, 2009, 08:17 AM   #6
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
Thumbs down
if its bending the push rod its going to take out the cam also
spr_chicken is offline   Reply With Quote
Old September 24th, 2009, 08:39 AM   #7
litfoot
litfoot's Avatar
timming chain shot and vavles hitting piston!!
litfoot is offline   Reply With Quote
Old September 28th, 2009, 07:54 PM   #8
mseguin1984
member
mseguin1984's Avatar
over revving ? does he know the procedure for properly adjusting valves? you adjust the intake when the exhaust closes and exhaust when the intake opens. take to zero lash and go another half turn. Hope i helped
mseguin1984 is offline   Reply With Quote
Old October 17th, 2009, 05:43 AM   #9
Yetti
Yetti's Avatar
I forgot to update this thread. it was a bent valve jammed shut! it has a bur built up on the stem and apparently slowed it down enough on the return to let the piston catch it once or twice.
Yetti
Page generated in 0.20081 seconds with 50 queries
