chevy s10 4x4 problem please help!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2009, 03:17 PM   #1
cjh4676
cjh4676's Avatar
Angry chevy s10 4x4 problem please help!!
I have a 2001 s10 zr2. When i put in it four hi or low the rear changes like when i hit 4low the rear is in four low its in the gear but the front diff will not lock in?? the transfer can in shifting over and lockin but some times when i try it there will be a grinding nose for the t-case like its not engaging all the way? idk what it is im sure it something eletric if you can help please message. Thanks
cjh4676 is offline   Reply With Quote
Old September 20th, 2009, 11:27 PM   #2
jmw55018
Oh poop
jmw55018's Avatar
umm maybe be a little more clear in your description but im thinking that maybe your actuator in your front axle isnt working.
if the t-case is shifting fine and the front wheels are not engageing then your actuator isnt functioning. its very common for them to go bad.
jmw55018 is offline   Reply With Quote
Old September 20th, 2009, 11:34 PM   #3
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Could you give us some more details? Do those have IFS? Does it have CAD?
brandonjb is offline   Reply With Quote
Old September 21st, 2009, 12:13 AM   #4
blownexploder94
Todd
blownexploder94's Avatar
let me know if you need any wire diagrams or anything, i would try to scan it for any codes first
Old September 21st, 2009, 12:20 AM   #5
blownexploder94
Todd
Default here is a pic of the front axle
a little more information on this would make this a little easier
Old September 21st, 2009, 01:03 AM   #6
blownexploder94
Todd
Default any of this help
dont know if this has anything to do with your problem
Old September 22nd, 2009, 04:14 PM   #7
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Your acutator is bad, don't know if its electric or vaccum....it was in the old s10s but don't know about newer ones....
Old September 23rd, 2009, 05:19 AM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
don't know why your having issues. on the old ones I used to replace about 50-100 vacuum switches a year at the dealer.
Yetti
Old September 23rd, 2009, 12:00 PM   #9
cjh4676
cjh4676's Avatar
Default f
The t case is locking but the front wheels are not that's all and it is electical
Old September 23rd, 2009, 06:41 PM   #10
Yetti
Yetti's Avatar
if the front axle up graded to the style like the full uses then it would have two plugs, one for the sensor and one for the actuator. if the actator is the screw in style like the full size ones it uses a heating element to expand a gas charge. they do go bad or take a very long time to warm up when bad.
#19 in the image is the actuator
Yetti
Old September 23rd, 2009, 06:57 PM   #11
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
your 2001 S10 has a vaccum switch and vaccum actuator. The actuator should be under the battery tray. Pull the line off and start the engine and engage the 4x4. You should have vaccum on that line. If you do not the problem is likely either the vaccum switch its self or one of the vaccum lines is leaking. If you Do have vaccum on that line then the vaccum switch is good as well as the line, and the problem is likely to be the actuator or the cable from the actuator to the front axle itself. There is a chance you have a problem in the diff but these are the most common causes for your problem. Hope it helps.
BAD93SBLZR is offline   Reply With Quote
Old September 23rd, 2009, 07:00 PM   #12
Mclovin
"The Situation"
Mclovin's Avatar
F it. swap out your IFS for a Dana super 60 and take care of any future problems too
Old September 23rd, 2009, 07:05 PM   #13
Yetti
Yetti's Avatar
Thats what I thought too? I been out of the dealer too long, I'm starting to second guess myself? I thought I was sure that model still had a vacuum system.
Yetti
Page generated in 0.41447 seconds with 63 queries
