01 burb temp gauge - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2009, 05:49 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default 01 burb temp gauge
my wife's 01 suburban with the 5.7 is "running" hot, Just started the gauge will go all the way to about 240 deg and the check coolant temp light comes on. I turn the heat on and it is Nice and hot, I checked the rad fluid level and its good.
Could it be a coolant temp sensor?
What else should I be looking for?
mideerslayer is offline   Reply With Quote
Old September 17th, 2009, 06:40 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
The sender is a good possibility. I can't remember if the LS engines used 2 senders for coolant with one being the gauge and the other going to the computer or if it ran one for all. Does it run good yet, not running odd? Could try plugging in a scanner and see what the comp is seeing.
Old September 17th, 2009, 07:53 PM   #3
mideerslayer
NEVER GIVE UP!
it is running fine, i will go get it scanned in the am and see what's up
Thanks
Rich
Old September 17th, 2009, 08:25 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
only other possibility if it has higher miles is simply a thermostat going bad. definatly want to see if the sender is bad or if there really is an overheating issue.
Page generated in 0.21203 seconds with 35 queries
