Crown Vic won't idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2006, 02:15 AM   #1
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
Default Crown Vic won't idle
Friends old boxy LTD Crown Victoria won't idle and dies when it's warm out. It has the EFI 5.0. Just did a basic tune up and that didn't help. Any 5-oh guys know what the problem may be?
Arnie897 is offline   Reply With Quote
Old June 30th, 2006, 09:07 AM   #2
Bones
Bones's Avatar
does it throw a CEL?
Does it idle any better in N?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 30th, 2006, 01:03 PM   #3
wakebabe
Mrs. Bones
HAHA the VIC! my best friend had a crown vic that was passed through the family when they lived at home...man...that car brings back some memories and good stories!
sorry for the tangent :tonka:
wakebabe is offline   Reply With Quote
Old June 30th, 2006, 02:39 PM   #4
Arnie897
y=mx+b
Arnie897's Avatar
I don't think that car has a working CEL. Neutral is same as park and drive.
Old July 1st, 2006, 04:12 PM   #5
frdboy
frdboy's Avatar
Have you cleaned the throttle body and the throttle plate?
Also there is a filter under the pcv in the rear of the lower intake. these filters plug and cause excess blow-by into the tb, coating the throttle plate.
I can get you the motorcraft part number for the filter tomarrow.
Adam
Old July 1st, 2006, 04:30 PM   #6
Tonka
Tonka's Avatar
Wonder if that was one of the not so wonderful motorcraft ignition module years...
Old July 1st, 2006, 05:02 PM   #7
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Check your vaccum lines.
max5p33d is offline   Reply With Quote
Old July 4th, 2006, 06:21 PM   #8
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Check the EGR vave.
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old July 4th, 2006, 06:36 PM   #9
Arnie897
y=mx+b
Arnie897's Avatar
What is the best way to check a EGR valve or a vaccume line?
Old July 5th, 2006, 06:27 AM   #10
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Listen for hissing. There is a T-shaped vacuum fitting in the very rear of the engine towards the passenger side that is known for going bad. Take a look there.
Old July 26th, 2006, 08:48 AM   #11
smasheromalley
smasheromalley's Avatar
What year crown vic? I have an 83 with TBI 302 while the newer ones (85+?) where TPI 5.0's
*edit* Whoops, sorry. reading Pwns me.
Old July 27th, 2006, 12:41 PM   #12
Calvynandhobbs
Calvynandhobbs's Avatar
My Crown Vic was a little newer, but I had an idle problem and replaced the TPS (throttle position sensor). Never had a problem after that. My 94 Bronco had the 5.0 also and I had to replace the same sensor on it. It would die everytime I was coming off the highway, especially if I had the cruise on. Nothing like driving 65mph and your engine stalls abruptly.
Roger
Calvynandhobbs is offline   Reply With Quote
Page generated in 0.34126 seconds with 59 queries
