Tires? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2009, 04:40 PM   #1
Disturban
Disturban's Avatar
Default Tires?
What kind of tires should I get on my Suburban for towing my 6,000lb travel trailer I just got? Load Range C, D, E? I also use this truck for my DD in the winter and off roading so I would like keep the ride comfortable. Right now I have standard load range tires, I am thinking of getting BFG A/T's with a C or D load range.
Old September 16th, 2009, 04:44 PM   #2
gmotox
gmotox's Avatar
D minimum, with c load you will get alot sidewall sway.
Old September 16th, 2009, 04:46 PM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Get a D rated tire.
Old September 16th, 2009, 04:52 PM   #4
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Do the d!
IFS SUCKS is offline   Reply With Quote
Old September 16th, 2009, 05:07 PM   #5
Disturban
Disturban's Avatar
How do D's ride when not loaded?
Old September 16th, 2009, 05:14 PM   #6
gmotox
gmotox's Avatar
A little stiffer than C, but not as stiff as E
I wouldn't put less than a D on suburban in any case. They will be alittle firmer on the road but won't roll as bad in corners. I would think you will find it an improvement in ride.
Page generated in 0.20717 seconds with 41 queries
