F-150 ignition - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2009, 04:49 PM   #1
cjric
cjric's Avatar
Default F-150 ignition
I've got a 95 F-150 w/ a 5.0
It has intermittent spark and usually wont start. Every once in a while though, it will. I've swapped out the coil, ignition module (on the fender) and condenser. After swapping the condenser yesterday it fired right up, so I thought it was fixed. This morning, it started once, and wouldn't start again after that. The only thing I havent replaced is the pickup in the dist.
Anyone have any insight?
Anyone know if I can remove the pickup w/o removing the distributor?
cjric is offline   Reply With Quote
Old September 16th, 2009, 05:10 PM   #2
You have to pull the distributor as it has a pin you need to remove to pull the shaft out to remove the pick-up
Old September 24th, 2009, 04:50 PM   #3
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Before you tear it apart, if you haven't already, look at the pick-up. Its not uncommon for them to collect dirt. You might be able to get away with blowing the dirt off the magnetic sensor. A Q-tip works decent.
Daddy Dan is offline   Reply With Quote
Old September 24th, 2009, 08:22 PM   #4
frdboy
frdboy's Avatar
Make sure you check the connection at the coil, they are known for making poor contact and causing a no spark. Also make sure the wiring to the noise suppressor (capacitor) isn't contacting ground.
Do you have a tach (factory of aftermarket)?
Old September 25th, 2009, 03:24 PM   #5
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
just replace the entire distributor its 90 bucks complete from the local auto store. i had the same problem with my 87 5.0 and it solved that problem runs awesome now as a plow truck for my buddy.
muddywater is offline   Reply With Quote
Page generated in 0.19524 seconds with 38 queries
