onboard air using S10 compressor? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2009, 07:01 AM   #1
knaffie
knaffie's Avatar
Default onboard air using S10 compressor?
Pulled all my AC stuff out, but the compressor is still there and works fine. If OBA is an easy setup with this compressor, I'll probably do it. If not, I need to find a pulley.
Anybody done it? Any links for me to look at?
Thanks for any help.
Old September 16th, 2009, 08:44 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what year and style compressor? i did a set up on my dodge using a chevy compressor. heres some pics.
Old September 16th, 2009, 08:49 AM   #3
knaffie
knaffie's Avatar
Sorry, its a 1995. As far as the style......... ?????????? I think its like yours. I'll get a pic tonight.
Do you have any air / electrical schematics on your setup?
Old September 16th, 2009, 09:05 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
ok then yes it's like mine. i have a 95 s10 and it's the same. as far as electrical it's simple 2 wire hook up. one side goes to ground the other goes to a switch for power. if you wanna spend more money get a pressure switch. i didn't use one because i designed it so then when it reachs 125 psi the belt will start to slip letting me know it's full. but if im airing up a tire or using a impact gun i can leave the compressor on and it'll keep the air flow up.
Old September 16th, 2009, 09:09 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
dont forget to add a filter and oiler to the compressor intake or your compressor wont last 1 trip... granted those types compressors arent known to last that long ina OBA app anyway
Old September 16th, 2009, 09:12 AM   #6
knaffie
knaffie's Avatar
Why is it they don't last? What one should they be considering if not this one?
Old September 16th, 2009, 09:15 AM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
everyone says you have to use a york compressor. i had my OBA system for over a year in working order and used it quite often. i didn't have any troubles with it.
Old September 16th, 2009, 09:21 AM   #8
knaffie
knaffie's Avatar
If its really that simple to set up, since its already in my truck, I might plumb it in. If it quits after a little while, oh well.
Which side of the compressor is output? One port has a big hose, one port has a small hose...... I assume I just filter the inlet hose and run the outlet hose to a tank. Saw one guy that had one on his rig that shot a little bit of synthetic lube through the filter every now and then to keep it lubed up.
Old September 16th, 2009, 04:56 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what i did was remove the hoses and tapped the outlet for 1/4 pipe thread. easy way to find out is to spin the compressor and see which has the output. i had mine run to a tank that had a pressure gauge as well as a air fitting for air hoses and such.
Old September 17th, 2009, 11:51 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
dont need a york per say but ive heard sanden style's last a while.. hell if you've got it run it.. if it lasts it lasts.. you're only out the money for wire and hose
Old September 18th, 2009, 03:09 PM   #11
MILKTOST
Flexes like a bulldozer
MILKTOST's Avatar
The small port is the outlet, larger port is inlet.
I'd run the factory inlet/outlet manifold at the compressor.
You can plumb the inlet side to a fitting on your intake elbow, between the filter
and throttle body, this will ensure you have clean filtered air.
I'm still tryin to find the part numbers for the pressure switches,
I'll post em as soon as I find em.
MILKTOST is offline   Reply With Quote
Page generated in 0.24832 seconds with 56 queries
