Front 44 limited slip ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2009, 05:37 PM   #1
IDIeselman
IDIeselman's Avatar
Default Front 44 limited slip ?
What is is man? My friend wants to buy a rebuild kit for it. It was removed from a 78 bronco, I thought it was a Factory trac lock but I'm not so sure after closer inspection. Help a brother out.
Old September 16th, 2009, 11:21 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
was that removed from a Ford front axle?
It appears it is a standar cut ring gear, in 78 ford had the high pinion D44 in the Bronco, which has a reverse cut ring gear
Is this possibly a LS from a D44 rear axle?
Old September 16th, 2009, 04:42 PM   #3
IDIeselman
IDIeselman's Avatar
It could be, He was told it came from a HP44 and it was a trac lock factory locker.
Old September 16th, 2009, 04:45 PM   #4
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Maybe it's the pic, but that looks open to me.
brandonjb is offline   Reply With Quote
Old September 16th, 2009, 07:31 PM   #5
IDIeselman
IDIeselman's Avatar
Thanks fsumotorhead, It certaintly is not from a HP44.
It is some sort of limited slip. I think I'll do what I told him to do in the first place.........Scrap it.
Old September 17th, 2009, 11:03 AM   #6
fsumotorhead
N8KVB
that or rebuild it and use the it it in a hp44
the carriers are interchangeable, i was mearly pointing out that it probablt didn't come from a bronco, that is if it actaully if for a d44 to begin with.
it would be pretty hard to clean it up/rebuild to usable conditionif, it was me, i'd probably pitch it
Old October 4th, 2009, 10:06 AM   #7
BIGBADCJ5
= Broncoholic =
BIGBADCJ5's Avatar
Soak it in a anti rust solution with a battery charger it is a trac loc.
BIGBADCJ5 is offline   Reply With Quote
Page generated in 0.21702 seconds with 44 queries
