lets talk Ford trucks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2009, 12:09 AM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default lets talk Ford trucks
so a diesel is just a pipe dream at this point..
Dodges Hemi sucks..
Gm's 6.0 is great but shitty mileage
what's Ford got to play ball with ?
im talking new or newer trucks like 06+
2500 + 3500 trucks 4x4
i know im asking for a lot in a HD truck with 4WD to get 16/17 or better MPG (empty)
Old September 14th, 2009, 12:19 AM   #2
boggin-machine
boggin-machine's Avatar
ford has ta new diesel coming out. 6.7 diesel.
i really like my duramax. its comfy to ride in. the diesel has tons of power stock or with a chip.
the ifs isnt that bad. depends on what you wanna do?
the 07 and new lmm duramax has some nuts to it. change the exhaust to a non dpf system and throw in a edge with juice programmer and you are set. run no more then 85 horse tune on a normal basis and you will never have a problem. the allison tranny is hard to beat.
the dodge cummin package is awesome. but the 6.7 doesnt get such great mileage with all the new emmissions crap its got bolt to it. plus the truck's interior is less the desireable. some will argue this is the truck of choice simply cause of the cummins, i dont care for dodge trucks. i would buy a cummins though.
ford doesnt have anything to offer as of now besides the 7.3
but even then why would it be a pretty common swap to drop a cummins into the ford.
it will be interesting to see what the new 6.7 has going for it. the had a article about it in my magazine i just got but i havent read it yet
Old September 14th, 2009, 12:31 AM   #3
barry1me
Just another day
barry1me's Avatar
I have owned two Dodge hemis, one 6.0L vortec, 3 5.4L Fords. I am a ford person to the core, but out of these options I would have to pick the 6.0L GM engine for a gasser.
For me a gas engine is a gas engine once you put a trailer behind it they are all turds.
For a diesel its another story...3 6.0L powerstrokes, 2 Duramaxs. One day I would like to own a cummins.
barry1me is offline   Reply With Quote
Old September 14th, 2009, 12:35 AM   #4
boggin-machine
also im sure ridendirty will comment on his ford thoughts.
Old September 14th, 2009, 12:51 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
HI DID YOU NOT READ THE 1ST FUCKING SENTANCE I TYPED !
Old September 14th, 2009, 12:54 AM   #6
Blacklung
Blacklung's Avatar
The current 6.4s have proved to be awesome motors so far. They had some problems with the job 1 and 2 '08s, but they've been straightened out. The 6.4 is untouchable with a Spartan.
But to answer the original question, Ford is still offering the Triton V8 and V10. The V10s are pretty strong runners, but still only average 10-12 mpg.
Blacklung is offline   Reply With Quote
Old September 14th, 2009, 12:58 AM   #7
boggin-machine
yes i did, but the price tag of a diesel is not that much more then a gas powered truck when you get into that year range of trucks
Old September 14th, 2009, 01:02 AM   #8
Shotgun
I only wheel with boats.
Shotgun's Avatar
my brother in law only manages 11mpg average with his v-10. Pulls like a mule though.
Old September 14th, 2009, 01:46 PM   #9
benny87
Young Gun..!
benny87's Avatar
What are you pulling? If your just pulling your little s10 thingy why not get a 1/2 ton. My friends sister has a new f150 and he uses it to haul his mowers around when hes not using his SD. We used it to haul my dads willies Jeep. I know its not alot of weight but they say its suppost to be a good hauler. And good gas.
Also my dads 6.7 gets 660 miles to a tank.. So thats somewhere high when he did the HAND calcs.
But if you need the 3/4 ton than I beleive the 6.0 is the best.
benny87 is offline   Reply With Quote
Old September 14th, 2009, 01:49 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
usually my s10 and 2 or 3 quads.. its not really a load that requires a 2500 but it's quite a bit for the 1500.. plus down the road i'd like to look into a bigger gooseneck
Old September 14th, 2009, 02:56 PM   #11
benny87
Young Gun..!
benny87's Avatar
Ahh makes sense now... Well good luck with the search..
Old September 14th, 2009, 03:11 PM   #12
butters
It curves to the left...
butters's Avatar
Get an older cummins, don't even fool with the others, i can get 14 mpg pulling a
24 ft trailer with a jeep and the bed full of crap and have plenty of power to spare
highway driving i have seen 18 mpg.
butters is offline   Reply With Quote
Old September 14th, 2009, 03:59 PM   #13
If you are looking at gas trucks:
Dodge, you already know the story.
Chevy: If you can find an 8.1 Liter, in my experience, they do just as good as early 6.0 gas motors, with more power.
Chevy half tons, outside of vortec max/1500Hds are too light, IMO, for pulling more than one vehicle on a trailer. Physical weight, the 10 bolt rear, and the 4L60 trans are all against you. Fine for towing your S10, but S10 + some, hmmm..
The 6.0 or 6.2 1/2 tons would do it. They'll get the same mileage as the hemi. Newest trukcs have 6 speeds which helps. You can run 3.42 gears and still have really low first gears for towing.
Ford, the heavier F-150s would probably handle pulling that load as well. Bigger rear axle than the chevys. Can't get lower than 3.73s, I think, though. 09s are 6 speeds, and much nicer than the 08s and previous, at least to me, and I've driven both.
You aren't likely going to get 17 hwy in any gas 3/4 ton, unless its low to the ground 2wd, and you drive real grandpa-like.
I bet for 3/4s, the 5.7 hemi, 6.0 GM, and 5.4 ford all get just about the same mileage, probably like 12 city, 14hwy or so? Maybe 15. The rear world tests that I've seen don't show it.
If you want a 3/4 ton and a gasser, I'd find an 8.1 Chevy with an Allison trans.
As soon as I can find the cash, I'm getting a 2009/2010 F150 crew with the 5.4 + 6 speed, awesome truck. Plenty for towing my Jeep. With backup camera that can see the hitch, trailer brake controller, all that jazz.
Old September 15th, 2009, 07:31 PM   #14
barry1me
Just another day
barry1me's Avatar
From my experience......
my 03 2500 dodge 4x4 hemi got 10 in the city and 12-13 why
2009 Ford 250 4x4 5.4l got 11 city and 13ish hwy
2004 Chevy 2500 4x4 6.0l got 12 city 14 hwy
Pullying a 4000 lb trailer all of them got around 9.5-11 on highway
Old September 15th, 2009, 07:37 PM   #15
special k
special k's Avatar
i hauled my jeep and quad on a 20' open trailer up to the dunes and back, along with 7 trips to the mounds or so with a 07 f150 supercrew 6.5' bed and a 3v 5.4L and it did just fine. it works a little hard getting going and on hills, but weight was never an issue, and it had the
9.75" rear end with 3:55's. the same truck with 3:73's would prolbably be better.
so basically any 04-08 of the same combos would work just fine.
Old September 15th, 2009, 07:53 PM   #16
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
My brother in law has an 03 Silverado Z71 with 3.73 gears. He put a programmer on it and beefed up the rear springs. He pulled a trailer for a guy who's V10 ford van had a hard time pulling. It's on it's third rear end now but we all know the Gov Loc is junk. I told him the first time to swap in a 6 lug 14 bolt but he didn't. I have an 05 Z71 with 3.42s and it leaves a little to be desired in the towing area but I get 16.5 MPG in mixed driving.
Oh yeah the Fords that you wanted to talk about. My dad has an 97 with the 4.6 and it is a turd but I had a 93 250 4x4 with an IDI 7.3 that towed my jeep like a dream. It even got 14.5 mpg doing it with 360K on the clock. I think alot of people talk down about them since they aren't turboed but they can be had cheap. I had $1000 into mine.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old September 15th, 2009, 07:56 PM   #17
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
I pull with a 98 Ram with a 318/auto. total load weight of trailer and rig with gear is 7k lbs and get 10mpg
BUTLER pulls with an 03 Chevy 2500 HD, gasser,auto( forget the MTR size, pm him) he pulls the same weight and gets about 12mpg
Skooterbuilt has an 03 F250 supa duty 7.3 powerstoke, auto trans and pulled 17K LBS and averaged 16-17 mpg at 70mph
I know Diesels ARE A FUCKING PIE DREAM FOR YOU( as you stated before), but I referenced the SD and HD trucks because they were bought for the same amount of money and both are quad cab 4x4's,loaded with less than 90K miles on the ticker
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
Deaner is offline   Reply With Quote
Old September 15th, 2009, 08:00 PM   #18
special k
special k's Avatar
honestly for what he's towing though a newer heavier ford 1/2 ton is more than enough.
Old September 15th, 2009, 10:09 PM   #19
Thats what i'd do. Get a 2009 with the max trailer tow package.
Old September 15th, 2009, 10:15 PM   #20
special k
special k's Avatar
ya. i really like everything about the 09 f150 but the 6 speed trans, i like the 5 speed in the 04-08 much better. the 6 speed seems like it never really builds enough RPM's to get up and go before it up shifts. but other than that i really like it. much quieter better ride than the 04-08.
Page generated in 0.36972 seconds with 83 queries
