Samurai \ tracker trans ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2009, 10:02 PM   #1
19914x4blazer
ps4 tag chevytruckguy82
19914x4blazer's Avatar
Default Samurai \ tracker trans ?
would a tracker trans and t-case fit in were the Samurai trans goes?
thanks mike
19914x4blazer is offline   Reply With Quote
Old September 13th, 2009, 10:57 PM   #2
A4X4SPIT
A4X4SPIT's Avatar
what exactly do you need to know? what engine do you have in your samurai?the tracker set up dosent bolt to the 1.3(altho Im sure it could be done) are you talking auto or 5spd? are you trying to get the tracker trans & t/c before the sami t/c to make a doubler? this pic shows a tracker engine trans t/c set up(with a samurai t/ next to a stock samurai set up enginerear transmounting surfaces lined up.
A4X4SPIT is offline   Reply With Quote
Old September 14th, 2009, 09:19 PM   #3
19914x4blazer
i have a 1.6 8v in my samy i was asking if a 5speed 4x4 tracker trans and t-case would fit in the samy trans spot. like would the t-case hit the floor? would i have to cut the trans tunnel it get it to fit? not trying to make a doubler i just want to get rid of the divorced samy tcase because my case is broke.
thanks mike
Old September 15th, 2009, 09:30 AM   #4
A4X4SPIT
A4X4SPIT's Avatar
Im not sure about the 5speed Ive installed a tracker automatic & it required some floor mods (with no body lift) and of course new drive shafts & x members the tracker rear d/s comes out the center & sami rear end is offset th tracker 5 speed shifter is abour 5 inches farther back than a samurai (measured from the ft of the bell housing) I looked at the stuff I got out & itlooks like both manual trans are about the same width its not any harder to modify the floor than it is to make x members mounts&driveshafts required hope that info helps
Old September 15th, 2009, 08:21 PM   #5
19914x4blazer
Ok thanks I will just have to get one and see what happens
Page generated in 0.14548 seconds with 38 queries
