spark then no spark, spark then no spark - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2009, 10:56 PM   #1
rkcbvw
rkcbvw's Avatar
Default spark then no spark, spark then no spark
one minute my 4.3L v6 (from a 1999 silverado currently resting in my cj-7) starts fine and will idle as long as I have gas. Then 10 minute later I try to start and I get no spark. 10 minutes later I am getting spark again and starts and runs like a champ. I replaced the ignition coil- no change. Seems to be random on if I get spark or not. What else could it be besides ignition coil? I am running factory computer and harness. Thanks for the help.
rkcbvw is offline   Reply With Quote
Old September 11th, 2009, 11:51 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Crank sensor going AWOL maybe? I remember the crank sensor synched the ignition and the cam sensor (plastic distributor) took care of the injection. You can unplug the dist and i would still run but the injectors would batch fire instead of sequential.
That's one guess, hopefully I'm going in the right direction.
Edit: Ok. Here's another. The ignition control module. It's next to the coil. They can get some heat in it and it expands and the internals lose contact. It don't happen often in either case, but stranger things have happened.
Old September 12th, 2009, 12:22 AM   #3
Disturban
Disturban's Avatar
I would bet the ignition control module is bad...seen many many GM's do this.
Old September 12th, 2009, 07:59 AM   #4
rkcbvw
rkcbvw's Avatar
that might be. This problem started after a hot morning out at silver lake. Things were warm.
There is probably no way to test this?
Old September 12th, 2009, 08:04 AM   #5
Disturban
Disturban's Avatar
You can test them but it will probably come back as a good part. When places like autozone test them it is not under real world conditions like 220 degree under hood temperatures. When they get hot they fail, cool off and it works again. Good news is there are millions of them in junk yards, go get one for about $10 and see if that fixes the problem. Brand new I think they are about $70.
Old September 12th, 2009, 09:33 AM   #6
rkcbvw
rkcbvw's Avatar
my problem does not seam to be 100% tied to heat. The problem started after a hot day of driving but I can walk up to it cold and it wont start then 10 minutes later starts like a champ. Other times I walk up to it cold and it starts right up, shut off and restarts shut off again, 10 minutes later no spark.
It still seems like you are right, I am going to try the local junk yard today. Thanks for the tip.
Old September 12th, 2009, 12:08 PM   #7
Disturban
Disturban's Avatar
Yep I said the junk yard because it is an intermittent problem so you might have to throw a few parts at it before you find out what it is. It could also be your ignition, bad ground, pick up coil, ect ect. I would test to make sure you have power to the distributor when you dont have spark, that will at least narrow it down to inside the distributor. Then if you can find a cheap one I would just pick up a whole new distributor at the junk yard that way you know you got the problem and will have some spare parts in the future. I have some U pull your own parts junk yards by my house and could probably get a whole distributor for about $20 maybe $25.
Page generated in 1.72441 seconds with 44 queries
