1986 Truck Gauges - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2009, 03:51 PM   #1
billywilly92
billywilly92's Avatar
Default 1986 Truck Gauges
I bought stock chevy gauges with a speedometer, tachometer, temp, oil pressure, voltage, and gas to replace my stock one that had speedometer, gas, and I think thats it. Now the new one I got only has wires coming out of the tach for ground, power, and one goes to the distributor I think. How do I wire the tach up and how do I get all the gauges to work? Like the oil and temp gauge I don't know how to hook up. Anyone know how?
billywilly92 is offline   Reply With Quote
Old September 12th, 2009, 12:16 PM   #2
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
You'll need to connect the tach wire to the tach port on the dist next to the Battery connection. You'll also need a tach filter. For the other gauges to work you need the proper sending units. The idiot light sending ubits won't workwith gauges.
Old September 14th, 2009, 05:33 PM   #3
billywilly92
I think I found all the correct sending units and gauges on summit. I had a mechanical gauge for the oil pressure before so that is why I was confused because I need an electric one not a mechanical one.
Old September 20th, 2009, 07:10 PM   #4
billywilly92
Which of these two do I need? Is one for the idiot light and one is for the actual gauge?
http://www.summitracing.com/parts/SMP-TS6/?image=large
http://www.summitracing.com/parts/SMP-TS71/?image=large
Page generated in 0.15678 seconds with 35 queries
