NV4500 4X4 trans offers SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2009, 12:05 AM   #1
ghetto fab
Yeah....That too....
ghetto fab's Avatar
Send a message via AIM to ghetto fab
Default NV4500 4X4 trans offers SOLD
i have a NV4500 trans with bellhousing clutch master and slave cylinders flywheel and clutch assembly from a chevy truck wantin 500 bucks for it
may trade partial what ya got?
SOLD
ghetto fab is offline
Old September 11th, 2009, 08:40 AM   #2
jeepcj
breakin frogs legs
jeepcj's Avatar
Is anything wrong with it?
jeepcj is offline
Old September 11th, 2009, 10:27 AM   #3
ghetto fab
ghetto fab's Avatar
not to the best of my knowlege parted truck never drove it shifts into all gears where it sits now thats all i know
Old September 11th, 2009, 08:59 PM   #4
fabricator
throttle jockey
fabricator's Avatar
what year ?
fabricator is offline
Old September 11th, 2009, 10:02 PM   #5
ghetto fab
ghetto fab's Avatar
All I can say is early 90s. Late 80s and that's a guess. The cab on this beast was an 89 but it truly was a frankentruck
Old September 14th, 2009, 11:43 AM   #6
ghetto fab
ghetto fab's Avatar
btt they mated these to a 205 in some cummings trucks
Old September 14th, 2009, 11:52 AM   #7
JONSON
where are you located? I would like to come and look at it. JONSON
JONSON is offline
Old September 14th, 2009, 03:34 PM   #8
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
any idea how hard it would be to mate up to the 4.0 in my TJ ?
two_much_talk is offline
Old September 14th, 2009, 11:28 PM   #9
ghetto fab
ghetto fab's Avatar
im in mt.morris and i dont know how hard it would be honestly....bellhousing is removable so ya may be able to fab one?
Old September 14th, 2009, 11:36 PM   #10
ghetto fab
ghetto fab's Avatar
http://saginaw.craigslist.org/cto/1357788943.html
this guy did it lol
Old September 16th, 2009, 11:31 PM   #11
ghetto fab
ghetto fab's Avatar
btt
Old September 21st, 2009, 09:13 AM   #12
ghetto fab
ghetto fab's Avatar
offers?
Old September 21st, 2009, 11:40 AM   #13
3-foot
3-foot's Avatar
It should be a 1993-2005 according to this....
http://advanceadapters.com/resources/974/NV4500.html
The New Venture Gear Corporation was developed when GMís Muncie Transmission Division and Chryslerís New Process Corporation joined forces to manufacture a full product line of manual transmissions. The NV4500 transmission was the highlight of this new venture. Featuring a granny low first gear coupled with a fifth gear overdrive, the stout NV4500 is truly the best of both worlds.
First introduced in 1993, the NV4500 is a constant mesh helical geared, heavy duty 5 speed transmission. All forward gears are fully synchronized. The initial Dodge version offered a synchronized reverse. The transmission case is cast iron with an aluminum top cover. The case measures 12.375 inches and features dual PTO ports. The shifter handle typically allows for better accessibility over older granny 4 speeds as it is located further rearward at 9-1/2" from the face of the transmission.
The 1993 & 1994 GM versions have a lower first gear of 6.34 and can be identified by a smaller front bolt pattern with a top to bottom measurement of 4.685". After 1995, the first gear and front bolt pattern reverted to the Dodge 5.61 first gear and the taller top to bottom 6.043" bolt hole configuration. The synchronized reverse was also added and the front bearing retainer was enlarged from 5.125" to 5.6" diameter. As a general rule, a GM NV4500 4WD transmission will always have a 32 spline rear output shaft with an 8-1/8" rear tailhousing. The input shaft is 6-5/8" 1-1/8" 10 spline with a .590" pilot tip. We have also seen a rare 1995 GM NV4500 which can be classified as a hybrid. The transmission has the lower 6.34 with the newer bolt pattern
Dodge 4wd NV4500 transmissions have always maintained the same gear ratios and bolt patterns throughout production; however, variations occur between diesel (and V10) versus gas models. Diesel NV4500 4WD transmissions always have a 29 spine rear output shaft with a 6-1/4"" rear tailhousing. The input shaft is 7-1/2" 1-1/4" 10 spline with a .75" pilot tip. The front bearing retainer index is 5.6" with a snout diameter of 1.75"
Dodge Gas 4wd NV4500s initially were introduced with a 23 spline rear output shaft and a 6-1/4 tailhousing. The input shaft is 7-1/2", 1-1/8" 10 spline with a .75" pilot tip (we have seen very rare 19 & 23 spline inputs). The front retainer is 5.6" with a 1.43" snout. In 1999, Dodge discontinued the 23 spline output shaft on the gas version NV4500, and all Dodge transmissions standardized to 29 spline.
For most conversion applications, we like the Dodge gas version transmission with a GM input shaft. This allows the shortest transmission length for most applications. The GM input shaft from a 6.34:1 early transmission will not fit the Dodge transmissions.
3-foot is offline
Old September 21st, 2009, 11:51 AM   #14
ghetto fab
ghetto fab's Avatar
sweet thanks!
Old September 25th, 2009, 11:27 AM   #15
ghetto fab
ghetto fab's Avatar
btt anything?
Old September 28th, 2009, 11:26 PM   #16
ghetto fab
ghetto fab's Avatar
btt
Old September 30th, 2009, 11:41 PM   #17
ghetto fab
ghetto fab's Avatar
not even an offer?? SOMEONE has gotta need this!
Old October 1st, 2009, 06:14 AM   #18
fabricator
throttle jockey
fabricator's Avatar
pm sent
Old October 1st, 2009, 09:27 AM   #19
ghetto fab
ghetto fab's Avatar
replied deal pending
Page generated in 0.29923 seconds with 80 queries
