project blue thunder - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2010, 06:54 PM   #141
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
you should fix or do something about that tie rod for sure
coolgareray is offline   Reply With Quote
Old February 3rd, 2010, 06:55 PM   #142
N8sBroncoMI
Boones Farmer
N8sBroncoMI's Avatar
Originally Posted by blue thunder View Post
yeah dave they work out great thanks alot man im very happy the way they sit now just waiting on the rear leaf springs to get here and maybe this thing will be on the road
hahaha you're joking, right?
N8sBroncoMI is offline   Reply With Quote
Old February 3rd, 2010, 07:38 PM   #143
blue thunder
blue thunder's Avatar
dicks i ment ride height the way the coils sit is garbage
blue thunder is offline   Reply With Quote
Old February 5th, 2010, 07:14 AM   #144
coolgareray
NMU Trailcat Alumni
if you're going to build some garbage you may as well come up with names for the garbage you attach to it along the way... like my radius arm mounts
http://nmutrailcats.informe.com/oper...t1008-140.html
Old February 5th, 2010, 08:51 AM   #145
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
Looks like you need to push your front axle forward now. I had the same problem with my bronco after changing out springs. other than that its still looking pretty good.
Old February 5th, 2010, 06:15 PM   #146
blue thunder
yeah i need to connect the radius arm brakets to my crossmember to equal it out
Old February 8th, 2010, 02:51 AM   #147
coolgareray
NMU Trailcat Alumni
someone needs to quit beejing off and work on their rig, mine may be done before this one, so far it's taken me 2 weekends to get my 44 in and i just have to do steering and brakes
Old February 8th, 2010, 09:41 PM   #148
blue thunder
alright if i can get my leaf springs it would be done and driving
Old February 17th, 2010, 11:22 PM   #149
coolgareray
NMU Trailcat Alumni
is this thing ever going to be done?
Old February 18th, 2010, 02:08 AM   #150
N8sBroncoMI
Boones Farmer
what did you do about your nutral safety switch?
Old February 18th, 2010, 11:43 AM   #151
blue thunder
i havnt messed with it yet but i have it all planned to be grounded to the block
Old February 18th, 2010, 11:50 AM   #152
CreativeFab
used to be Ironman
CreativeFab's Avatar
Hopefully your leaf springs (the right ones this time) will be there tomorrow or at the latest monday.
Old February 18th, 2010, 12:21 PM   #153
blue thunder
thats what im looking forward too then i just have to figure out how im going to get it out of the garage
Old February 23rd, 2010, 12:12 AM   #154
coolgareray
NMU Trailcat Alumni
air the tires down.
you scrap this thing yet?
pm me a price on ur front shafts
Old February 23rd, 2010, 12:16 AM   #155
N8sBroncoMI
Boones Farmer
garb
Old February 23rd, 2010, 05:27 PM   #156
blue thunder
leafs came today thankfully this should be finally done soon
Old March 3rd, 2010, 12:43 AM   #157
coolgareray
NMU Trailcat Alumni
Project blue shitter now is complete with torque converter bolts after 10 minutes (7 weeks later) 5.5" rear springs (surprisingly) a tight tranny and inspection plates are tight and tranny drain plug and a starter are set
still to do
-hook up trans lines
-fill with trans fluid 3.5-4 qts actually probably a lot more cause when we tipped the trans a lot came out
-fill t case
-attach tranny crossmember
-measure and drop off driveshafts
-attach battery cable
-attach t case linkage linkage
Old March 12th, 2010, 05:59 PM   #158
blue thunder
i pushed it out of the garage today to check the height wasn't bad can't wait till the 36's are under it
Old March 15th, 2010, 11:25 PM   #159
coolgareray
NMU Trailcat Alumni
pics of the drive shaft
Old March 16th, 2010, 07:29 PM   #160
blue thunder
what a great day the jeep is finally done and driving on the road off tomaro to get the 36s mounted up
Page generated in 0.39086 seconds with 83 queries
