project blue thunder - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2009, 01:22 AM   #81
N8sBroncoMI
Boones Farmer
N8sBroncoMI's Avatar
how did the gear lube look in that old ass rear end when you changed it?
N8sBroncoMI is offline   Reply With Quote
Old October 19th, 2009, 01:33 AM   #82
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
i like how u assumed it was a full spool, not even a mini or welded just to realize it may be an lsd hey wait maybe you'd know if u changed the gear lube and didn't run the shit from the 79 Bronco
don't you also mean 260 for the axles?
as you also haven't changed the gear lube have you checked it and when do you plan to install those rear 4.10 gears? be sure to see if the axle bearings stay together when you pull the shafts otherwise you're going to need new ones like i did. there is a seal like pressed in with the race and it comes out with the shaft on the bearing
you get rear shocks on yet?
coolgareray is offline   Reply With Quote
Old October 19th, 2009, 01:42 AM   #83
N8sBroncoMI
Boones Farmer
your only getting that much flex because you dont have rear shocks to limit your flex
Old October 19th, 2009, 08:56 AM   #84
blue thunder
blue thunder's Avatar
still havnt changed the fluid and i sold the bronco for 100 so 160 brah
and the front shocks limited front flex and still waiting on the rear those quatratec fucks
and yeah i am going to need to pull the 3rd and throw the 4.10 in there i need money to purchase the front 4.10 and carrier and i wil have to see what the hell is in the rear 3rd cause it could be a swaged out track lock from 79 and i probaly blew it driving it around the last 3 weeks cause its 30 years old if thats the case i may rebuild it i may put a mini spool in it or a full i dont know yet
blue thunder is offline   Reply With Quote
Old October 19th, 2009, 09:38 AM   #85
N8sBroncoMI
Boones Farmer
Garbage
Old October 19th, 2009, 12:06 PM   #86
blue thunder
what do you think mini spool and be done with it or what
Old October 19th, 2009, 12:18 PM   #87
N8sBroncoMI
Boones Farmer
well id figure out with is acctually in it first, and probably go with a aussi locker because i dont think you want to be skiding your bald tires every day makeing them balder.
Old October 19th, 2009, 02:23 PM   #88
blue thunder
when i get money its not going to be driven everyday
Old October 19th, 2009, 05:42 PM   #89
N8sBroncoMI
Boones Farmer
then id leave it open until said money arrives then throw the $20 mini in.
Old October 19th, 2009, 10:16 PM   #90
blue thunder
yeah good idea you find the right combanation joint yet
Old October 19th, 2009, 10:40 PM   #91
N8sBroncoMI
Boones Farmer
I dont know what garys problem is i have had 2 of them in my tool box forever. and one is still in the box with the NAPA part number on it. So when are you going to bring up this pig and take it wheeling? get your shit together.
Old October 19th, 2009, 11:03 PM   #92
blue thunder
haha thats something i need to do get my shit together im thinkin after my birthday next friday buy sye front pump seal for the tranny pull it do it all in one shot then no more driveline vibrations and she will be able do highway driving a bit better i dont know if she'd make it all the way up there 7 hrs but well see time will tell im gettin 8mpg with these garbage 3.50 gears
Old October 19th, 2009, 11:20 PM   #93
N8sBroncoMI
Boones Farmer
im rockin the 3:50 gears with 36" swamp donkeys and a v8,
Old October 19th, 2009, 11:37 PM   #94
N8sBroncoMI
Boones Farmer
The gear lube you never changed...if there is any, is probably as thick as clay and comparably draging down your gas milage in the same way that driveing around with your e-break on would be.
Old October 20th, 2009, 02:12 PM   #95
blue thunder
yeah i should probaly change that soon do you have to pull the shafts to get the 3rd out and change the fluid
Old October 20th, 2009, 02:33 PM   #96
N8sBroncoMI
Boones Farmer
yeah. get an axle shaft puller...or i made one. the 3rd weighs a fukc ton and it takes over a gallon to fill it back up...i always loose count
Old October 20th, 2009, 06:42 PM   #97
blue thunder
alright good to know how did u make a shaft puller
Old October 20th, 2009, 08:03 PM   #98
N8sBroncoMI
Boones Farmer
i took a 5x5.5 rim and welded a plate over the hub hole, then welded a pipe to it. slid a thicker pipe over it half as long and then welded a stop on the end. its pritty much just a home made slide hammer welded to a old bent rim
Old October 24th, 2009, 09:44 AM   #99
blue thunder
show me a picture of the one you made
Old October 26th, 2009, 10:51 PM   #100
coolgareray
NMU Trailcat Alumni
it's pretty self explanatory
pretty sure you can rent one from o rileys too.
Page generated in 0.27876 seconds with 83 queries
