4.3 to 5.7 tpi swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2009, 10:10 AM   #1
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
Default 4.3 to 5.7 tpi swap
like the title says im wondering if i need to change wiring harnesses if im going from a 4.3l tpi to a 5.7l tpi, or is it plug and play so long as i change the computer out as well?....i tried googling couldnt find anything on this swap but found plenty for tbi to tpi swapping. thanks
OL RED is offline   Reply With Quote
Old September 10th, 2009, 10:21 AM   #2
Disturban
Disturban's Avatar
Yep just change the computer and everything else is plug and play. You do mean on a TBI motor not a TPI motor correct?
Old September 10th, 2009, 10:37 AM   #3
OL RED
OL RED's Avatar
no i mean tuned port im getting a 93 with a 4.3 tpi and have a line on a 5.7 tpi was wondering if its all plug and play.
im kinda curious are tpi and tbi harnesses the same if so ill just put in a tbi.
Old September 10th, 2009, 11:01 AM   #4
Disturban
Disturban's Avatar
If you are going from TBI to TPI you will need to change wire harness and computer. If going from a 4.3 TBI to a 350 TBI you can use the same harness and just change the computer.
Old September 10th, 2009, 11:04 AM   #5
Disturban
Disturban's Avatar
PS: If going from TBI to TPI you will also need to upgrade fuel pump because TPI requires more pressure.
Old September 10th, 2009, 12:56 PM   #6
OL RED
OL RED's Avatar
no no no im going from a tpi 4.3 to a 5.7 tpi is it all plug and play as far as under the hood. tpi to tpi
Old September 10th, 2009, 01:00 PM   #7
OL RED
OL RED's Avatar
alright i found out its cpi not tpi the guy selling the 4.3 truck said it was tpi which never cam in s10's. so now i know i have to change harnesses thanks for the help.
Page generated in 0.22123 seconds with 44 queries
