SOLD M1 Carbine .30 Cal Rifle SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2009, 04:57 PM   #1
Jhoskins
Default SOLD M1 Carbine .30 Cal Rifle SOLD
Hello,
I got accuired this gun from my great grandpa a few years back. I do not know much about it, especially the value, I was hoping you guys would be able to help me with that. I did shoot the m1 a few times at the range when we first got them, it shot fine.
It is a universal M1 Carbine .30 Cal Rifle.
I do know I am looking for a Remington 870 Express 12 gauge or similar shot gun. I know I need to put a price and I will say $300. I really do not know if that is way to much or a great deal, I dont want to be ripped off.
Thanks,
Joe
Jhoskins is offline
Old September 9th, 2009, 05:07 PM   #2
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
This site is a good reference for prices
http://www.gunbroker.com/
I think you're at a fair price.
SlayerXJ is offline
Old September 9th, 2009, 08:39 PM   #3
copper
sent you a pm
copper is offline
Old September 9th, 2009, 10:33 PM   #4
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
if you can post some better pics i will take a look at them.
some things that are important in the value of a m1 carbine are:
-it has a the early no bayonet barrel band
-what is the manufacturer stamp on the receiver behind the rear sight? it will be inland, rock ola, national postal meter, IBM, saginaw, etc.
- is the bolt round or flat? if it is round it is a m2 bolt.
- does the upper handguard have 2 or 4 rivets in it?
- what style rear sight is on it?
- does the stock have any stampings on it? worth way more if it has a winchester potbelly stock.
- is there a slot carved out of the left side of stock next to upper receiver? if so it's an M2 stock.
- check the stampings on the safety, lower receiver and magazine release.
if it's the universal reproduction your price would be accurate.
a matching manufacture of original parts easy in the $750-$1000 range.
a hodgepodge of original parts $450-$500
ovrlnd is offline
Old September 10th, 2009, 07:57 PM   #5
wannawrangler
how much $ R good jeeps
wannawrangler's Avatar
NOT Really! its worth just as much as someone will give you for it! I hve found gunbroker HIGH
wannawrangler is offline
Old September 10th, 2009, 08:04 PM   #6
Jhoskins
Posted more pics at the top.
-I dont think it has a bayonet barrel band.
-The manufacturer stamp on the receiver behind the rear sight only says the serial, 105038
-In front of the rear sight it says, Universal, hialeah. fla.
-The upper handguard has 4 rivets in it.
-Dont know what kind of sight, no markings on the stock that I see.
-The magazine release has the letters, M W A, the M is sideways.
Jhoskins is offline
Old September 10th, 2009, 08:40 PM   #7
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
no the barrel band is of the earlier style that didn't have the bayonet lug. the 2 rivet upper handguard is a later war production as the earlier ones used only 2, but they often broke. the stock appears to be an m1 but the lower front area is flat which would not make it a winchester potbelly. the rear sight if early would be a L shaped flip peephole sight. yours is later but the the more desirable higher quality adjustable one. the bolt is flat making it an M1 bolt. (M1 and M2 parts are largely interchangeable with differences in the the M2 being selective fire in semi and full auto. the m2 stocks are a bit wider as is the lower receiver due to the extra parts for the selective fire parts)
the stock appears to have a gloss which would have been added later as issue carbines featured the oil-dipped finish.
here are some things that will help you decipher markings
B- IBM
W - Winchester
N - National Post Meter
RMC - Rockola
I - Inland (WI - Winchester for Inland, AOB - Auto Ord for IBM, etc)
AO - Auto Ordanance (sub contractor)
Q - Quality
SG - Saginaw
S'G' - Saginaw Grand rapids
IP - irwin Pederson
U - Underwood
serial number blocks can be found here.
http://home.att.net/~ra-carbines/history.html
marking codes
Inland Division of General Motors AI A1 IA II UI KI KI [inverted] II [circled] SI [circled] AI Note: Inland codes including an "A" were reportedly made by Autorye Co. For GM Inland Division
C. Cowles & Co. C
Saginaw Steering Divison of G.M. KSG S'G' OI-S'G' G- S'G' SP-S'G'
and some more Saginaw codes... U-S'G' O-SG K-S'G' ISG KSG (inverted)
IBM SY-B OI-B OI B
International Silver IS
Irwin Pedersen K-IP I-P-K IP-I C-IP UP
National Postal Meter UN MN
Quality Hardware UQ QU G-Q
Rock-Ola IR R-C RO RC R-G UR
Rugg Mfg. Co. (Greenfield, MA.) RUGG
Seymour Smith SS SS-4 R-SS
Standard Products SO SP
Stanley Works SW
Underwood IU LU UU IU [circled]
Union Hardware U
Wade Electric Products WEP [in curved type]
Winchester BW IW UW IW [circled]
ovrlnd is offline
Old September 10th, 2009, 11:16 PM   #8
Ebrown
Ebrown's Avatar
Pm ya!
Ebrown is offline
Old September 11th, 2009, 07:22 AM   #9
JeepRat
Infidel
JeepRat's Avatar
http://www.maxicon.com/guns/universa...m1_carbine.htm
info on Universal
JeepRat is offline
Page generated in 0.55951 seconds with 50 queries
