Cage Design Ideas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2009, 04:25 PM   #1
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
Arrow Cage Design Ideas
I have a few projects planned for the Lucky Charm, all of them are stemming from or needing the roll cage done first. I decided to start designing a cage but I need input/ideas. I am really just starting to research it, so I could be going about this all wrong.
Plans:
- Get Seats and 4pt harnesses.
- Retain access to the rear seat through the front door
- Mount both front and rear seats to the cage
- Tie the cage to the frame
- Be able to use hard top and soft top
- Hard doors must be useable
* Finite Element analysis
* I will probably design the cage in Pro/E and do a finite element analysis so I can see how strong it is and where the weak points are. I am currently in the class learning how to do it, so I'll wait until I get good at it then post my results. I will also have to take measurements to get the drawing to scale as right now the drawing is just thrown together.
Current Rollbar:
Here is a round idea/start for you guys to tear up: (it will have gussets and other things, I am just getting a quick rough idea out there to see if I am heading in the right direction.) I think it may need some triangulation in the rear window area.
I changed the color so you can tell the differences of some of the bars starting and ending points:
Front:
Side:
Top:
LuckyCharm4x4 is offline   Reply With Quote
Old September 9th, 2009, 05:56 PM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I'd rake the windshield and c hoop more. Just my opinion though.
For belts and seat room that b hoop is going to have to lean back at least 10 degrees. Even then your b hoop bracing is going to have to have a bend in it to clear seat backs. If your looking for ultimate strength you want to try and brace the outside nodes on the perimeter with triangles. Your top bracing from B to C is fine, do it that way all the time. The to bracing from A to B is done a lot in sport cages and when headroom is tight. If your going for capacity to take a hit on the top of the A hoop, you want to run your spreaders from the center of the B hoop to the outside corners of the A.
All the above applies only if your willing to give up your vision for strength. I've built a lot of cages, so for mine I took what I had in my head and had mike draw it and we bent it up. There are few places where a hit will deform the cage enough to scrap it. I have no question on it's ability to save our lives though... I just don't care if it gets destroyed doing it.
JcrOffroad
Zoom Zoom!
Old September 22nd, 2009, 03:59 PM   #3
DUNE JUMP
DUNE JUMP's Avatar
I have always liked putting a slight bend on top connecting tubes where they intersect hoops, etc. In my opinion, it requires more tube deformation before it causes a life-threatening failure at the cage node.
Old September 22nd, 2009, 04:13 PM   #4
95geo
newbie
95geo's Avatar
I think theres a lot of useless bends in it that dont need to be there. Beyond that my personal preference is that I dont like hoops or halo's. I like "one" tube that runs the A pillar past the B pillar and turns into the C pillar or rear spreader so that it's harder to get hung up on trees and stuff. It gives you more interior room too in the corners.
$0.02
Old September 22nd, 2009, 04:31 PM   #5
trailrail302
Im going FAST!!!
trailrail302's Avatar
I agree with having one continous tube from A-pilar back. My chassis is that way slides off things better and it gives it a cleaner look. I do like the halo look in the back $.02
trailrail302 is offline   Reply With Quote
Old September 23rd, 2009, 11:55 AM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I drew mine out... than when I actually started to bend, new ideas came to me that made more sense.
Old January 15th, 2010, 04:40 PM   #7
LuckyCharm4x4
I appreciate the input guys, keep it coming!
I have changed my ideas around due to looking up the cost of steel tubing and such. I came up with a new design that is just add-on's to my existing stock YJ rollbar. Below you can see my new design idea. The light color is the existing bar and the dark pieces are the additions. This design would be straight forward and decently simple. I think that this is way better than what I have now, and what most people wheel with. What do you think?
the main reason for keeping the "sport bar" is I might put an overhead console between the bars. right now I have no where safe to keep my radio/CB so I don't even run it. But I do realize it's not quite as strong.
~Bry
Old January 16th, 2010, 01:35 PM   #8
kj kyle
kj kyle's Avatar
I would attach the 2 spreader bars between the A and B pillar to the rear most points...
like this... (monkeyevil's old cage)
BTW, kudos on the CAD skills.
kj kyle is offline   Reply With Quote
Old January 18th, 2010, 08:52 PM   #9
Chief Brody
Get off my lawn.
Chief Brody's Avatar
I would definitely incorporate bars for your seats to mount to. Might just be me, but I don't see the point in having a full roll cage if you aren't attached to it....
Chief Brody is offline   Reply With Quote
Old January 19th, 2010, 11:16 AM   #10
LuckyCharm4x4
I will be attaching my seats to the cage. As for the rear section, For now I am just leaving it. I will be incorporating a whole family cage one day so for now I'll leave it. Also, when I go to do that, I may just upgrade the whole thing at once and build a cage from scratch.
~Bry
Old January 19th, 2010, 11:29 AM   #11
benny87
Young Gun..!
benny87's Avatar
Here are some models of cages that I have done, to spec but I have/will be changing some things to my personal cage.
benny87 is offline   Reply With Quote
Old January 19th, 2010, 11:38 AM   #12
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Hrmm nice work guys
Old January 20th, 2010, 12:18 PM   #13
LuckyCharm4x4
I am wondering, has anyone here built a cage so that you could have a 4-pt harness but still get in the back seat easily? Maybe a detachable bar or something? Or does everyone just get rid of the back seat access with their cages?
~Bry
Old January 20th, 2010, 06:58 PM   #14
Chief Brody
Get off my lawn.
~Bry
I tell whatever unlucky asshole that has to ride in back they have to climb over the bar.
Actually, my Jeep hasn't moved since the roll cage. So I haven't actually told anyone that. But when it does move, that's what I'll say.
Old January 20th, 2010, 07:15 PM   #15
boggin-machine
boggin-machine's Avatar
climb through the jungle gym
Old January 21st, 2010, 02:16 PM   #16
LuckyCharm4x4
A little refined: After measuring the thickness of the 2 existing stock spreader bars I found that they are 0.088" thick. This is thin compared to the 0.120" thick of most aftermarket cages, so I will be replacing them. The reason I kept with the hoop to windshield design is because this really keeps my windshield sturdy both when topless and when the hardtop is on. Yes, the cage is getting pretty far from stock and is basically becoming a built from scratch cage, but the main hoop is still in tact, which is what I was really trying to shy away from having to build. What do you think now?
Note: Again, the rear portion will maybe be completed one day, but by then I may just build a complete cage from scratch. Building this add-on cage right now will let me see some pros and cons so I will know what to change for next time.
~Bry
Page generated in 0.35893 seconds with 71 queries
